I like this, lets find out if they did find YOURS???? Or they can't and are trying to sqeeeeeeeeze out of it........throw a hitch in their gettyup, tell them you want your radiator back
I think the radiator I am getting is 2 row which is the same style that came with the car when I got it. It seemed to cool the car just fine for the first part of the summer. I did not see the temperature rise till after I swapped in the "lost" radiator. I am not too worried about it as we do not see many triple digit days here in Oregon. With a new heater core, water pump, fan clutch and radiator the cooling system should be happy.I would be thinking heavy duty cooling (3 row radiator)
It may have that anyway with AC
I would be thinking lifetime.
New radiators do not last that long these days
Yes, your old brass radiator is worth about 10 - 15 bucks at the salvage yard easy
Yes lifetime warranty from Napa. Funny you mentioned the running water sound, I was hearing that when I started the car in the morning for a short while before the heater core let go. I thought it was because it was leaking and there was air in it when I started it? I will still look, just have not got to it. I have a reducer if there is not one on this car. I bought it when I did the Saleen but I did not end up using it as there was one already installed.Good job, Snappa has a warranty anyway right?
That restrictor made them less noisy
Ford used to have us put them in the Lincolns et al. for complaints of water running sounds TSB
With the restrictor, you should have no loss of heat
I changed it Labor day weekend. It probably has ~1500 miles since I changed it. No idea the last time it was done. The fluid that came out of it was brownish. Not terrible though. I have seen worse.When was the last time you changed trans fluid?
I do mine about every thirty thousand miles.
