Ok, going to build a 351(400) for my 95 and the car will be a weekend street driving car, non track, N/A. Recently replied to some forums on 408s and some and most say why pay for a dart when you can save lots of $$$$$$$$$$ on a stock block. Well I asked my builder that question and this is his answer:
" Wait until you drop money on a stock block only to do that 5 times to learn each block is no good. Then you understand you could have paid for a dart block ".......
So in that theory, sure I would not want to have to hope that I find a good block then it's no good or what have you then have to spend more money and more money until I find one. So enlighten me on the process you guys would take to find the stock block. I guess if you knew someone who had one and knew them pretty well and if it was their block, then you may be more comfortable trusting their word. And I guess you have to factor in also if the block was hit with Nitrous or not also. He ( whomever) could really say and with conviction the block could be good as of the last time they used it and when you put it together it cracks lol. I'm not sure how all of that works, rather there's testing you would do and all that and what's the costs involved, ect. I will not be shooting any block I go with also, FYI.
My components are likely to be :
?? block
3.750 crank to make it around 400 C.I.
custom cam by the builder
Box R intake more than likely
AFR 205 cc heads
Fox TB setup
Anderson powerpipe ( what size recommended for a non track weekend driver street car)????
( I know as for the pipe, the TB needs to be the same or at least 5 mm smaller)???
What would you guys recommend for what I just said I will use the car for?
95 5 spd
?? block
AFR 205 cc heads
Fox TB setup
95 5 spd
