Does stock replacement crank need balancing?
Tremec77
I just had my engine freshened up with new rings, bearings, and freeze plugs. I reused the rods and pistons. If I replace the crank with a stock replacement crank from Summit, will I have to take all of the rotating assembly and get it balanced? Like I said, the crank is the only thing that I am changing. The reason I am replacing the crank is that it has some rough places on it and I AM NOT GOING TO TURN IT because it has already been turned once.
FWIW I called Summit and they said it was a direct drop in replacment but I'm not sure I trust them.
  • Sponsors(?)
2000xp8
SN Certified Technician
Aug 8, 2003
6,870
1,025
194
NJ
Balancing is always a good thing, new or used.
If it fits your budget, just get it balanced for peace of mind.
vristang
4,786
41
109
44
Seattle
www.SeattleBlueOvals.com
DO NOT TRUST SUMMIT TECH LINE ON THIS.
Crank, rods, pistons
If any one of the 3 are replaced, then balancing is a good idea.
Take EVERYTHING to the shop.
Pistons/pins, rings, rods, crank, flywheel, clutch, and damper.
This would be the time to replace the damper or flywheel as well....
Thread starter Similar threads Forum Replies Date
Habu135 Fox : How Much Power Does a Stock 1993 Cobra Make? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
M Electrical Stock Tach Does Not Work Fox 5.0 Mustang Tech 20
99FiveOh Electrical How Much Power Does The Stock Ignition Have? 1994 - 1995 Specific Tech 1
Calypso5oh Where does your stock oil guage needle sit. Fox 5.0 Mustang Tech 10
BillyT903 Does a stock 1999 Mustang GT have a rev limiter? SN95 4.6L Mustang Tech 11
9 Does Anyone Make a Lightweight Stock Hood? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 15
WallyKilla Just purchased an 03 GT 5spd! Why does it feel slower then my stock 90 5.0? SN95 4.6L Mustang Tech 16
T Does '94 have a chin spoiler, stock? 1994 - 1995 Specific Tech 26
D does aftermarket x pipe and h pipe work with stock headers' bolt up Fox 5.0 Mustang Tech 2
D what does it take to upgrade a stock engine for serious boost 2005 - 2009 Specific Tech 4
jayrw 2000 GT - Does my car have stock gears? SN95 4.6L Mustang Tech 25
Mustang5L5 Does anyone make a Fiberglass or CF STOCK hood?? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
Black1987Stang Does a stock V1 S-trim setup use stock serpentine belt? PICS! Fox 5.0 Mustang Tech 7
conartist Does the explorer intake clear a stock hood? Fox 5.0 Mustang Tech 6
4.6andSlicks Why does this say "NOT for stock wheels" SN95 4.6L Mustang Tech 24
jhonda what does a stock 03-04 lighting run? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
S Does anyone have WheelReplicas 17x10.5" ANTHRACITE Bullitts in stock? 1994 - 1995 Specific Tech 4
MR.MACH 1 Mach 1 WHAT DOES A 05 ZO6 + BASE PUT TO THE WHEELS STOCK Special Production 4
M Mach 1 does anyone know the stock wheel size? Special Production 7
M Fox body stock h-pipe does not fit SN95 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
Mr_Q Does Roush wing cover the stock spoiler holes? 2005 - 2014 S-197 Mustang -General/Talk- 2
Mr_Q Does this sit on top of the stock grill? 2005 - 2014 S-197 Mustang -General/Talk- 1
1994Vib.RedGT does anyone know the stock valve spring tension Fox 5.0 Mustang Tech 0
1987stangman All fairly stock motors, what does your Fox idle at? Fox 5.0 Mustang Tech 16
R what does a stock 98 cobra run SVT Tech Forum 13
SteedaGT9150 How does my stock shift knob come off? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 23
C How does a bolt-on 4.6 2V compare to a stock 350Z? 1996 - 2004 SN95 Mustang -General/Talk- 39
mustangkid05 how much hp does every gt come stock with? 1996 - 2004 SN95 Mustang -General/Talk- 33
jackchan does anyone have any data on stock springs? Fox 5.0 Mustang Tech 0
N How much HP does a stock 94-95 cobra have 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
Power4 How does the stock system sound? 2005 - 2014 S-197 Mustang -General/Talk- 13
95Vert Does porting the stock MAF help any? 1994 - 1995 Specific Tech 11
yellowstang1994 How does a stock firewall peice go on a new cable! Help QUICK!!! 1994 - 1995 Specific Tech 2
'13_ImpactBlue_GT What hp does stock GTs dyno at w/ the 4R70W SN95 4.6L Mustang Tech 39
2 Does a Programmer and a tune help with stock to lightly modded cars? SN95 4.6L Mustang Tech 2
InMyPrimeSVT How many amps does the stock alternator put out? 1994 - 1995 Specific Tech 12
M How much does a stock cast iron flywheel weigh? Fox 5.0 Mustang Tech 9
G Does anyone have the stock 8" axle values? 1974 - 1978 Mustang II Talk & Tech 2
jb1dsl How much stress does a reverse manual v/body put on a stock bottom end? Fox 5.0 Mustang Tech 8
B How much lower does Trick Flow AOD pan sit from stock? Fox 5.0 Mustang Tech 2
R how does one Convert Stock MAF to 90mm lightning? 2005 - 2009 Specific Tech 2
SilverStallion Saleen S281 Spolier on a 2000 Mustang GT - Does it cover the stock trunk holes? SN95 4.6L Mustang Tech 15
foxfreak88 what does a bone stock 5.0 cound like??? Fox 5.0 Mustang Tech 29
garystocker does a 65mm FRPP throttle body work with stock Mass Air? Fox 5.0 Mustang Tech 7
SilverStallion Does March Make The Billet Pullies in the Stock Size? SN95 4.6L Mustang Tech 0
T Going from a stock GT, what does it take to run 10's in the quarter? SN95 4.6L Mustang Tech 20
TheDamned Curious, does a S\C fit on a stock motor ? 1994 - 1995 Specific Tech 9
brentwoodboy Street Heat, does it fit under stock hood? 1994 - 1995 Specific Tech 10
The Shape Does the stock starter work with a tremec 3550? Fox 5.0 Mustang Tech 9
4.6litrebeater how does the stock h pipe go back on?? SN95 4.6L Mustang Tech 12
