I just had my engine freshened up with new rings, bearings, and freeze plugs. I reused the rods and pistons. If I replace the crank with a stock replacement crank from Summit, will I have to take all of the rotating assembly and get it balanced? Like I said, the crank is the only thing that I am changing. The reason I am replacing the crank is that it has some rough places on it and I AM NOT GOING TO TURN IT because it has already been turned once.
FWIW I called Summit and they said it was a direct drop in replacment but I'm not sure I trust them.
