Double Flare?
TrophyHead
1,195
11
49
PA
I just a bought a brake flaring tool. My question is what does double flare mean? Do I have to flare it twice or something?
  • Sponsors(?)
Daggar
3,903
Making Single Flares
Before making a flare, make sure the fitting is on the tube first, or you will need to cut the flare off and put the fitting on and remake the flare.
Undo both sides of the flaring clamp.
Then insert the tube in the flaring tool with the end sticking out about 1/8" and tighten the clamp bolts
Then put the flaring press on and slowly tighten.
Then remove the flaring press, and remove the tube
You will have a beautifully made custom piece to fit your exact need.
Note again, however, that this single flare process is not to be used for brake lines. I show it on small lines mostly because I had the scrap left over and it was easy to demonstrate here, but most fuel lines are much larger. The double flare will be shown next.
Making Double Flares
The double flaring process is similar to the single except that a different tool is used and it it a two step process.
Again, as with the single flares, before making a double flare, make sure the fitting is on the tube first, or you will need to cut the flare off and put the fitting on and remake the flare.
Insert the tube into the flaring clamp so that it sticks out the same distance (red arrow) as the width of the collar on flaring die (blue arrow), then tighten down the clamp.
Now turn the die around and insert the pin into the tube.
Put the flaring press on and tighten till the black die is firm against the the tube clamp (red arrow in right photo).
Remove the flaring press and the black die and your tube will look like this.
Now put the flaring press directly on the previously made partial flare and slowly tighten the press till the flare is right against the edge of the clamp, as seen in the right photo. Then remove the press.
The left photo shows the new double flare still in the clamp. The right photo shows the finished product. You now have a great looking and functional double flare, suitable for brake lines, power steering lines, transmission cooler lines, fuel lines, etc.
Blatently Stolen from: http://www.joesfalcon.com/
Thanks Joe!
Thread starter Similar threads Forum Replies Date
M double flare questions Classic Mustang Specific Tech 15
F Changing 4inch stock center screen to 8inch double din 2015+ (S550) Mustang -General/Talk 0
L 78 mustang 2 double hump crossmember 1974 - 1978 Mustang II Talk & Tech 3
I Upgrading head unit in 2010 base, double din dash? 2005 - 2014 S-197 Mustang -General/Talk- 5
Mustang5L5 Interior and Upholstery Double din radio 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
J Double Din Android radio Digital Self-tuning Forum 7
D Double din 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
1hot87gt Double DIN radio in a Fox 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 19
Mustang5L5 Double Din stereo in a Fox 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
Chuckman Electrical Can someone double check this wiring diagram? Fox 5.0 Mustang Tech 0
99mustanggt2018 Double din in 99 gt?? 1996 - 2004 SN95 Mustang -General/Talk- 1
TAJ Trunk Ajar Light Always On/double Horn Beep 2005 - 2009 Specific Tech 0
USCGunner Question About Double Shocks On Rear Fox 5.0 Mustang Tech 5
JasonFOXBOD Expired Upgraded Gt40 Stud Mount Heads W/ Double Springs Engine and Power Adder 0
billison Double Check My 5 Lug List. Fox 5.0 Mustang Tech 4
billison Double Check My 5 Lug Parts List Please. Fox 5.0 Mustang Tech 21
Chazballard97 I Want To Put A Double Din Head Unit Into My 99 1996 - 2004 SN95 Mustang -General/Talk- 1
Bullitt347 SOLD Wolf Racecraft Double Adj. Upper Control Arms Suspension Parts 0
Bullitt347 Expired Wolf Racecraft Double Adj. Upper Control Arms. Suspension Parts 1
S Expired Fs: Saleen Lighted Double Sided Dealer Showroom Sign Other Classifieds 0
Grabbin' Asphalt Double Din Radio/gps 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 26
LaserSN95 SOLD Koni Double Adjustable Rear Shocks 87-04 Sra Suspension Parts 1
D Expired Fs: 05+ Bmr Double Adjustable Lcas - $180 Shipped Suspension Parts 1
woodsnake Double Check My Procedure Here.. Classic Mustang Specific Tech 4
68dustin Good Ol Holley Double Pumper Tunning Classic Mustang Specific Tech 3
flstang65 Suspension Double Down On Subframe Connectors? SN95 4.6L Mustang Tech 1
S double sump Fox 5.0 Mustang Tech 3
Pops Fun Double Din Radio 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 21
K Adjustable Double Hump Crossmember (ford Racing) Drivetrain Parts 3
R salt and pepper shakers (double) and................. Fox 5.0 Mustang Tech 5
92rohcp Crane Cams 99893-16 Double Valve Springs Engine and Power Adder 7
9 double din head unit install help Fox 5.0 Mustang Tech 6
jansen29 Holley 650 Double Pump for sale Mustang II Parts 1
S 94-98 REAL Saleen SR351W Double Spoiler/Wing Interior Exterior Parts 4
R JESSEL DOUBLE ROLLER FOLLOWERS MODULAR ENGINE Engine and Power Adder Parts 0
Stus99GT Double Din Swap - Radio problem SN95 4.6L Mustang Tech 9
PQTIII For Sale : Holley 600 double feed Engine and Power Adder 2
IIGood Double DIN mounting question 1996 - 2004 SN95 Mustang -General/Talk- 4
B leaking double pumper Classic Mustang Specific Tech 1
hoodrich racing Steeda double ajustable clucth cable Drivetrain Parts 1
2badazzstangs Saleen S351 Double Stack Spoiler NJ Interior Exterior Parts 13
O Holley 600 Double Pumper Carb Engine and Power Adder 2
spoulson Double DIN unit in a fox body? Mustang Sound & Shine All 3
blown5.0 Valve Springs, Trick flow, Double, SBF Engine and Power Adder 0
Reef Stock fuel pump with double gear drive timing chain Classic Mustang Specific Tech 3
hoodrich racing steeda double ajustable clucth cable Drivetrain Parts 0
1993SVT Double Sump Question Fox 5.0 Mustang Tech 1
CarMichael Angelo Need double groove w/p pulley 2.3L (N/A & Turbo) Tech 2
B Major electrical upgrades, DOUBLE CHECK MY WORK! Classic Mustang Specific Tech 3
6 double pumper tuning with sbf Classic Mustang Specific Tech 26
