Build Thread Dusty's Got A New Home
  • Sponsors(?)
90sickfox
I didn't really have an issue with the stink...
SN Certified Technician
Mar 2, 2015
5,210
4,283
203
42
Nothing to do on this beautiful Saturday...other than redoing the single hardest thing I did on this car. I dread what my weekend now looks like.
90sickfox
Mar 2, 2015
5,210
4,283
203
42
I'm replacing the cobra booster.
90sickfox
Mar 2, 2015
5,210
4,283
203
42
Almost there. Its complicated binge watching American Horror Story with the wife and getting anything accomplished.
I wish I could do like some of you guys and just clean, polish, paint, and beautify as I go. Unfortunately, my life just isn't set up like that right now.
Olivethefet
Slap me as well as point and laugh
May 17, 2018
1,562
994
123
39
Enterprise AL
No sweat man! Looking good. All any of us can do is just that. All you can do. You'll get to the making it pretty part in time. I think the pics make my car look better than it really is....
90sickfox
Mar 2, 2015
5,210
4,283
203
42
I do need to clean up some stuff... like this line lock. It's crazy how bad stuff can start to look just from sitting.
90sickfox
Mar 2, 2015
5,210
4,283
203
42
I swear man. This one stud has taken me an hour to get out the firewall. If I had a hack saw I would've cut it off. It's out now though.
I couldn't stand all the dirt...had to clean it up a bit. Might as well clean the firewall. Off to get some more supplies.
90sickfox
Mar 2, 2015
5,210
4,283
203
42
New booster is in. Just need to bleed the brakes. Other than putting everything back together.
....I couldn't leave the wiper motor with peeling paint and rust.
67coupe
634
360
83
Huntsville, AL
I feel your pain. Without a doubt, that was the most frustrating job I’ve done. Test fit booster, won’t clear the upper intake. Remove intake. Test fit again, wont clear valve cover. Remove valve cover, dent strut tower, won’t fit. Slot holes in firewall, wont fit , slot some more, and on and on.
CarMichael Angelo
clearly, I’ve got something going on in that hole
13,609
234
62
Birmingham, al
m.imdb.com
Theres always the manual brake option...it’s the option 2 out of 3 Mike’s recommend for mechanics that work on their own sht.
90sickfox
Mar 2, 2015
5,210
4,283
203
42
I tried to widened the holes in the firewall and cut all 4 of the studs down. The issue with my car is that the plastic spacer between the firewall and pedal bracket is broken. The whole time you are trying to put the studs through the pieces are moving around. The lady wiggled the booster and I had to go under the dash with a long flat head. PITA. Got it done though....that's all that matters, right.
CarMichael Angelo
13,609
234
62
Birmingham, al
m.imdb.com
There is a gigantic notch in the corner of my strut tower when I installed the Cobra booster. The 2JY has dictated that that booster won’t fit....and it had to go. Im going to Hercu-Leg mode to stop my car. If I’d only known then what I know now.....
1. I wouldn’t have this big assed kerf in my strut tower.
2. I wouldn’t have this once silver, soon rusty-assed orange brake booster that I had to resell .( Sold).
90sickfox
Mar 2, 2015
5,210
4,283
203
42
Well... I've got more work ahead. I though my PCV valve grommet was leaking because I'm too lazy to use my scope to look behind the intake. Turns out my lower intake is leaking and making a mess.
This is where I'll stop for the night.
90sickfox
Mar 2, 2015
5,210
4,283
203
42
I understand completely, Mike. I really contemplated going hydroboost. Going manual would cost me too many pennies right now.
CarMichael Angelo
13,609
234
62
Birmingham, al
m.imdb.com
What?... It's a home made firewall plate, redrill the existing brake pedal, use the existing M/C,..and repurpose the brake lines.
Sounds like.....free to me.
90sickfox
Mar 2, 2015
5,210
4,283
203
42
I've got to buy the plate....and bolts....and I gotta make a rod to go from the pedal to said master cylinder...and I gotta find something to put through the pedal that will make the brake switch work.
Time is money....even if my time is only worth pennies.
90sickfox
Mar 2, 2015
5,210
4,283
203
42
Got almost everything disconnected from the intake. I've got the heater hoses and bypass assembly left. The engine is at TDC and distributor is marked and out. The only issue I have is that I didn't put this engine together. A very reputable builder put it together and ported the lower and the heads. I have no idea what gaskets he used. That was a long time ago...probably about 10 years ago. The engine sat for about 7 before going in this car.
A friend of mine name Pole had this built before he passed away. Another friend bought it from his wife and I acquired it from him. It seems like it has regular grade 8 bolts in the lower. I'm not a big fan and I'm leaning towards ARP hardware....or allen head bolts.
Determined the knock in my steering is coming from the inner tie rod on the left side. Guess I'll be doing that, too. The rear ones need to be done as well. They are the factory ones and are bent ( comes from hard launches and sticky tires ).
Hopefully, this covid19 stuff doesn't affect my funds anytime soon.
90sickfox
Mar 2, 2015
5,210
4,283
203
42
Thought I was getting furloughed from my company along with the 15000 that did get cut today. Found out its work as usual for me. Don't know if that's a good thing or bad....but I'll keep moving on. The hours even stayed the same. We are here twittering our thumbs most of the day.
I got to run out and buy an adjustable wrench for the bypass pipe assembly so I can get the intake off. Also need a drain valve for my el cheapo radiator.
90sickfox
Mar 2, 2015
5,210
4,283
203
42
This is a testament that sometimes it's better to just do stuff yourself. This engine came from a reputable, very well known, performance engine builder. This is what I found....
These are an assortment of parts bin bolts. Several of them are different lengths. This next picture shows that they aren't grade 8 either.
This also has to be one of the cheapest paper gaskets. This would've been an issue, too. The coolant ports are partially blocked. Intake ports were ported and the gasket did not go into them.
I'm so glad that I decided to tear into this. If I hadn't already been through the bottom end I'd have all types of questions.
Thread starter Similar threads Forum Replies Date
90sickfox DUSTY'S New Start After Intake Replacement Digital Self-tuning Forum 3
T Dusty engine bay 2005 - 2014 S-197 Mustang -General/Talk- 13
N Bought a unfinished 5.4 dohc into 97 gt project. I)ve got lots of questions. The Welcome Wagon 2
C Hi guys i just got a 2003 mustang gt 4.6 how do check kow it the car has pi heads SN95 4.6L Mustang Tech 6
M Progress Thread .351 roller, cam bearing cracks, I've got em #2 & #4 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
C Just got a 1990 lx notchback. I need help please 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
DudeStang Progress Thread Finally got my first Fox Body - 1988 GT 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 323
Twitch'n Twitcht4life My P.M.S. got stolen from my car. Hey 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
mattbaker302 Gots me a 351 Cleveland 1965 - 1973 Classic Mustangs -General/Talk- 12
R Have I got two faults SN95 V6 Mustang Tech 28
J Electrical finally got my head lights SN95 4.6L Mustang Tech 0
joetrainer31 Progress Thread Got Another One! Pics Fox 5.0 Mustang Tech 90
79 Fox Fox Got a problem... What is going on? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
79 Fox Fox Finally got my Fox running! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
S Engine Got a 93 mustang gt overheat on idle Fox 5.0 Mustang Tech 2
1970machwon Engine A couple MAF questions (Finally got my donor engine!) Fox 5.0 Mustang Tech 6
RangerJoe Fox New PB, finally got into the 10's! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 20
C Finally got this horse to pass NJ inspection !!! SN95 4.6L Mustang Tech 3
J Cheap fix for front bumper that broke off when I got the car stuck in a ditch. 2015+ (S550) Mustang -General/Talk 4
R 04 GT. JUST GOT IT. The Welcome Wagon 1
C Engine 88 got oil question Fox 5.0 Mustang Tech 11
CarMichael Angelo Well, I just got poked in the heart... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 18
R Please Help has anyone got image of wires The Welcome Wagon 0
John Dirks Jr What you got? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
W Hi All, Just got a 2002 mustang. It has 16 inch wheels and tires on it. Thinking about buying 18x9 front and 18x10 rear, any advice? 1996 - 2004 SN95 Mustang -General/Talk- 2
8 Just got my 2nd fox!! The Welcome Wagon 3
tessatrolo Got a wiring problem SN guys please help! 1996 - 2004 SN95 Mustang -General/Talk- 0
TNAVY Finally got a Cobra (my dream car!) The Welcome Wagon 1
C Hello from Texas. I am an old Street Rod builder who got serious about Mustangs years ago. The Welcome Wagon 5
R Finally Got to Mustang Week 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
mpeach1976 I got popped by police for my exhaust 2005 - 2014 S-197 Mustang -General/Talk- 2
J Engine 1994 GT not sure what I got here ... SN95 4.6L Mustang Tech 1
H 1986 got some turbo questions. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
S After 20 years, I got my Mustang. The Welcome Wagon 1
S Just got 18 GT. Ambient Light/ Primary/ Secondary color settings do not save when turned off. 2015+ (S550) Mustang -General/Talk 5
Steel1 Got myself a Fathers Day present 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
Z Just got stanged 2005 - 2014 S-197 Mustang -General/Talk- 1
65-Fstbk Rebuilt the 5.0 but it's got an oil leak 1965 - 1973 Classic Mustangs -General/Talk- 6
G Paint and Body Spring is finally here and got the car cleaned up. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
Justin Fetalvero Just Got A Free 1994 Mustang V6! The Welcome Wagon 3
Mustang Yawie Wow, It’s Been A While But Finally Got A Mustang Back 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
E Just Got A 74 Mach1 1974 - 1978 Mustang II Talk & Tech 11
FastDriver Finally Got To Drive A '16 Gt 2015+ (S550) Mustang -General/Talk 14
Chythar Interior and Upholstery Got Myself An Early Xmas Gift 1994 - 1995 Specific Tech 7
B I Think I Got Ripped Off Need Help! 1996 - 2004 SN95 Mustang -General/Talk- 4
IIGood Think I'm About To Go Broke...got A Polisher Mustang Sound & Shine All 0
Street Renegade Finally Got Headers And A Tune 2015+ (S550) Mustang -General/Talk 2
Davedacarpainter Who's Got The Best Eclipse View? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 25
mikestang63 Got The Latest Mm&ff Fox 5.0 Mustang Tech 3
9 How Warped Is This Cylinder Head? (just Got "resurfaced") 1996 - 2004 SN95 Mustang -General/Talk- 3
