electric fan not coming on?need help
Ductape91
14
i have a 91LX dp 2.3 5 spd and recently i noticed that my temp guage has been
getting up there lately. so one day i checked to see if the fan was working and it never came on, even when it got near the red. so to test the fan i ran the fan direct to the battery and it came on. at first i thought the coolant temp. sender might be bad but someone mentioned to me to check the fuses/relays for the first. only problem is i dont know what the owners manual is talking about there being fuses near the starter relay (i didnt see any?)
could someone shed some light on this for me, i would like to check those first before i go replacing stuff.
also to add, the fan never came on when i put my a/c on either. could it be cause of the fcm under the dash?
any help is greatly appriciated cause i dont want my headgasket to go "pop"
  • Sponsors(?)
rd
3,316
63
109
Ocean Springs MS
Visit site
This could take some serious checking. I have an 89, and had this. I believe the 91 is somewhat different.
In general, in these, the fan is controlled by the IRCM (integrated relay control module) or CCRM ( constant control relay module, I think). On my 89 LX it it a box under the dash to the left of the steering column that has 6 or 8 wires. A 91 or later may have the 10 wire CCRM that is mounted on the pass inner fender, under the hood. These turn the fan on based on both, or either, of the temp sensor and, or demand for AC. The EEC power relay is also operated from here on some. General function of both types is similar. Thank God, 5.0's don't have these...
The major issue is that, especially with the one mounted under the dash, battery power is sent to the module, and the fan is powered thru a relay that is on the circuit board in the module. So full power/amperage for the fan goes through the thing. The wire terminal connectors apparently get tired, the connection gets dirty, fails, overheat, and melt the plastic connector. Then you get no connection or such a poor one that the fan wont run, even when commanded on by the EEC and the IRCM.
If, with a demand for the fan, such as by the ac, you have power into the box, but none at the fan connector, this may be the issue.
Ford, and parts stores sell connector repair or pigtail kits to fix it. About $20. I melted the connector on two of them. The circuit board survived, but I also bought a new circuit board from Ford, $125. I replaced the fan motor just because. Then the new fan motor died. Instead of checking it out, I reinstalled the original fan motor and put a relay by the battery, operated by the former fan power wire, to run the fan. It has worked for almost 2 years, including 2 ac seasons...
mg man
142
At the time done it on the cheap on my 89 turbo.Done this on underdash type control.I ran a wire to solder joint of coil of relay. I think wire 1 and 8 spliced into will also work ran them to a external relay to the coil. I then cut wire 2 and 5 from relay put connections on them and plugged to normally open terminals on the relay. Board contols function as before. Amperage not on terminal strip. It has been like this about 8months works normal with temp sensor or AC . Remeber solder all joints.Hope this helps
Ductape91
14
thanks for the replies.
ill look into this tomorrow as ive been busy lately. most likely a trip to the dealer will be in order but no big, gotta pick up the im gasket and tranny seal for my 84 vert anyway.
Thread starter Similar threads Forum Replies Date
N Electrical Can you use the 4cyl electric fan controller in a 5.0 swap? Fox 5.0 Mustang Tech 4
F Electric fan 1965 - 1973 Classic Mustangs -General/Talk- 2
H recently installed alluminum radiator and electric fan on 89 5.0 overheating 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
Blown88GT For Sale Electric Fan Motor Engine and Power Adder 0
Blown88GT For Sale Small Auxiliary Electric Fan Engine and Power Adder 0
irishgt1 Lets talk electric fans 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
N Electrical 94 Mustang Wiring to fuel pump and cooling fan 1994 - 1995 Specific Tech 0
B Electric fan with fan switch Fox 5.0 Mustang Tech 10
James V Wiring these electric fans is confusing.. Fox 5.0 Mustang Tech 33
J 2007 v6 cooling fans/electric windows causing engine stumble 2005 - 2009 Specific Tech 5
A Electrical electric fan help Fox 5.0 Mustang Tech 7
A Engine electric fans,help Fox 5.0 Mustang Tech 3
lxhatch91 electric fan 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
S Electrical Dorman 620-104 Contour fan and connectors Fox 5.0 Mustang Tech 5
B Mishimoto Dual Fans On And Off 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
imp Sn95, No Electric Fan! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
R Radiator Fan And Wiring Mess 1994 - 1995 Specific Tech 6
B How Do I Wire The Electric Fan To A Switch 1996 - 2004 SN95 Mustang -General/Talk- 2
Scrasauge Electric Fan Cfm Sizing ? 1965 - 1973 Classic Mustangs -General/Talk- 2
gruvee87vertgt Jegs Electric Fan Reviews? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 14
stangboy What's A Good Electric Fan Controller? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 16
R Fox Coolant Temp And Electric Fan Issues 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
Dma1980 Expired Spal 16" Puller // Electric Fan Classic Mustangs For Sale 0
Gearbanger 101 Forced Induction Electric Fan Clearance With Vortech S-trim Fox 5.0 Mustang Tech 31
stang89bidges Electrical Proform Electric Fan Install - With Pics Fox 5.0 Mustang Tech 3
S 2006 V6 Spits Out Coolent, Temp Ok 2005 - 2014 Specific V6 Tech 4
horseballz Electric Fan Questions? Classic Mustang Specific Tech 8
A Electric Fan Overflow Setups Fox 5.0 Mustang Tech 9
Nate_745 Electric Fan Help?! Fox 5.0 Mustang Tech 2
D 03 Cobra Electric Fan Issue SVT Tech Forum 0
AUBURN1111 Electric Fan Controller 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 19
stangboy Engine Electric Fan Question Fox 5.0 Mustang Tech 2
AUBURN1111 Electric Fan Install Fox 5.0 Mustang Tech 15
90lxwhite SN95 Electric Fan Settings 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
R Electric Fans Not Turning On 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
OonDeanisS I Need Some Help With My Electric Fan Fox 5.0 Mustang Tech 9
Dyno12 Electric Fan Problems Fox 5.0 Mustang Tech 13
VonBerry Electric Fan Help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
gearheadboy Fox Switching To Electric Cooling Fan 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
boostfrk SOLD Dcc (delta Current Control) 2 Speed Electric Fan Controller Engine and Power Adder 11
Husky44 Electric Fan Temperature Sensor Location Fox 5.0 Mustang Tech 19
vince chiavetta Expired Aluminum Radiator With Electric Fans Engine and Power Adder 0
91redFox Electric Fan Probe? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
90lxwhite Electrical Electric Fan Choices Fox 5.0 Mustang Tech 44
MustangMando Need Help With Electric Fan On A 68 Mustang 1965 - 1973 Classic Mustangs -General/Talk- 5
Hanksta Electric Fan 90 5.0 Fox 5.0 Mustang Tech 38
MustangMando Electric Fan Vs Clutch Fan Vs Flex Fan On A 68 1965 - 1973 Classic Mustangs -General/Talk- 10
Jarvis Electric Fan Shutting Off Fox 5.0 Mustang Tech 23
larrym1961 $45.75 Ebay Contour/mystique Electric Dual Fan Out Cools $375 Flex-a-lite Extreme Puller! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
HuskerNation SOLD 15" Proform Electric Fan W/180-240 Thermostat Engine and Power Adder 0
