Excessive heat from engine bay
ultimate007
Banned
Aug 26, 2004
40
Southern California
I was cruising with 3 friends for the first time in my convertible yesterday and I had to bring the seat forward. After an hour of driving, I noticed my feet were getting real hot. I put my hand underneath the steering column and felt alot of heat coming from the engine. Is there anything I can do to reduce the heat? Upgraade the firewall or something?
thanks
  • Sponsors(?)
GinoGT
1,862
36
Bigger engines, more heat. Less tolerance for lack of cozyness, better off buying a Civic.
ultimate007
Banned
Aug 26, 2004
40
Southern California
Well, it is not that bad when I am riding with no passenger behind me so I could back up my seat and incline it. I do often have my top down. In the future, I will certainly add a different thermostat. I noticed that the engine temp goes a little beyond the middle when driving with the a/c on for some time.
Thread starter Similar threads Forum Replies Date
cdurbin Excessive Heat 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
M Misfire-Excessive Heat- Melting plastic smell- RPMs stay high after letting off pedal SN95 4.6L Mustang Tech 20
rayvinton excessive heat on rear brakes SN95 4.6L Mustang Tech 3
stang730 Will excessive heat kill batt? Fox 5.0 Mustang Tech 2
9646gt Is this excessive heat normal?!? SN95 4.6L Mustang Tech 17
ACSPONY Suspension Excess play in rear suspension, springs not staying in place Fox 5.0 Mustang Tech 6
D Excessive shaking during rev up 1965 - 1973 Classic Mustangs -General/Talk- 2
D Excessive sludge found 1965 - 1973 Classic Mustangs -General/Talk- 10
JCBeaver Drivetrain Excessive Vibration at 4K+ RPM while in gears - Any ideas why? 1993 Mustang GT 5.0 with T5 Fox 5.0 Mustang Tech 11
C 98 GT - excessive vapor coming out of one tailpipe in cold temp SN95 4.6L Mustang Tech 1
9 1994 Cobra 331 Dart Supercharged Excessive crankcase Pressure!! Help! 1994 - 1995 Specific Tech 6
W Engine Inconsistent idle and excessive vibration. Fox 5.0 Mustang Tech 17
F Excessive Play In My Steering Wheel Fox 5.0 Mustang Tech 4
rattlecan96gt Modular Headshop/excessive Motorsports 1996 - 2004 SN95 Mustang -General/Talk- 51
7991LXnSHO Allied Nationwide Insurance 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
S Fuel Excessive Fuel Pressure 98 Mustang Gt SN95 4.6L Mustang Tech 10
tbear853 How I Removed Excessive Rear Fender Gap .... Pics 2005 - 2009 Specific Tech 1
98blackstallion 320 Lph In Tank Fuel Pump And Stock Regulator? Excessive Flooding? 1996 - 2004 SN95 Mustang -General/Talk- 4
87_LX_5.0 Excessive Toe-in After Brake/suspension Install Fox 5.0 Mustang Tech 12
R Forged? 6spd? Preemptive or excessive? 2005 - 2014 S-197 Mustang -General/Talk- 11
92BlackWidowHO Hesitation/excessive Backfiring At High Rpms. Fox 5.0 Mustang Tech 16
Pvt_D Excessive smoke any help? Classic Mustang Specific Tech 1
DeadEnd Excessive Cranking?? 1994 - 1995 Specific Tech 10
9 Ring & pinion excessive backlash Fox 5.0 Mustang Tech 5
MRaburn Excess Ford Mustang stock flattens Ford?s Flat Rock facilities StangNet Site News 0
bgdowski Excessive rich condition Fox 5.0 Mustang Tech 5
R excessive drivshaft play? Fox 5.0 Mustang Tech 3
R excessive play 2.3L (N/A & Turbo) Tech 3
Platonic Solid Tire Age: Safety Hazard - Excessive Paranoia - or Sales Promo Classic Mustang Specific Tech 29
B Excessive Fuel Pressure Fox 5.0 Mustang Tech 3
SHOJOE Excessive coolant pressure? Fox 5.0 Mustang Tech 12
grey racer excessive rear brake pad wear 2005 - 2009 Specific Tech 12
98E9GT Excessive Ripple??? SN95 4.6L Mustang Tech 8
9 Piston ring end gap excessive on rebuild Fox 5.0 Mustang Tech 6
DarkoStoj excessive distributor shaft play, msd distributor Fox 5.0 Mustang Tech 2
myponyrocks Excessive shifter movement? SN95 4.6L Mustang Tech 13
hotcobra03 excessive wheel spin =clogged cac SVT Tech Forum 5
XavB excessive bumpsteer with 96 and up spindles Fox 5.0 Mustang Tech 9
deftsound Excessive accessory noise 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
Tom95gt excessive wheelhop 1994 - 1995 Specific Tech 8
T 331 Stroker Excessive Crankcase pressure problem 1994 - 1995 Specific Tech 12
T Excessive Crankcase pressure 1994 - 1995 Specific Tech 0
L excessive TV pressure Fox 5.0 Mustang Tech 1
nonglossjason brake floating too excessive Fox 5.0 Mustang Tech 8
R Excessive Play in Steering column after road race practice SN95 4.6L Mustang Tech 4
K overheating and excessive water leaking from exhaust Fox 5.0 Mustang Tech 5
Rickyll7 excessive gear whine GONE after 31 spline swap! SN95 4.6L Mustang Tech 4
grantur01 please help with excessive oil blowing out of motor. Classic Mustang Specific Tech 24
BlackVert loose header bolt = excessive valve noise? 1994 - 1995 Specific Tech 5
1 Engine Light: EGR Excessive Flow SN95 4.6L Mustang Tech 2
