im grounding my block to the frame for my chassis to engine ground, i put the strap on the back of the block to the firewall, and a 4 gauge ground from my passenger side motor mount to the sway bar bracket. the battery is grounded to the trunk.
few questions...
do you think a 4 gauge wire be good enough for my chassis ground?
is what i have enough? should i put a ground from the drivers side motor mount to the drivers side frame?
ground strap to block, other side goes to firewall
4 gauge from motor mount to the frame
few questions...
