OhNo- 5-0
For those who care to take a guess at the issue or have seen this issue before!-
As warmer weather nears, I'll be fiddling with the car to get more info. Here are the specs/ concerns:
-88 original 5.0 car Paxton novi 1000 supercharged with FMU
- (No chip in ECU)
-Car is still speed density
Issue: After reaching NOT, the car sputters at maybe 2300rpm-3000 rpm (sounds almost like fuel cut) . Before and after those rpms, car has good power and runs fine
Again, if anyone feels confident they have a good test for me to do before I begin to do the diagnostics, your knowledge would be greatly appreciated!!
Dump codes sticky.
Look at the top of the 5.0 Tech forum where the sticky threads are posted. One of them is how to dump the computer codes. I highly suggest that you read it and follow the instructions to dump the codes.
Step #1, run the codes
But, gonna go out on a limb here and guess that a supercharged setup on a stock SD system might be part of the reason. I'd run the codes first, aside from anything else obviously wrong, I'd suggest a Mass Air conversion to start
