i hooked up the meter to my car today and found with the key off and the doors closed it is pulling 0.20 amps. i dont know if this is a lot but i know my battery dies every 5 days or so. i tracked the problem down to 2 seperate sources. the #3 maxi fuse under the hood (starter relay, ignition switch) is pulling .05A. the other drain is coming from the #39 fuse inside the car. it is a 5A fuse and it is labeled GEM. it is pulling .15A with everything shut and no key in the ignition. i let the car sit for about an hour before tracking anything down and the door was open but the latch was in the closed position so the interior light was not on.
with both fuses pulled there is no drain on the battery.
can someone help me out with the next steps to getting rid of my problem??
