Front 5 lug conversion
Creomod
91
9
18
40
San Antonio,Texas
I’d like to covert the front of my car to use the center cap to my 5 lug wheels. I have svo rotors with the stock foxbody capilers. I’d like to keep those so my question is can I use a sn95spindle with my capliers so can I do that?
  • Sponsors(?)
Rdub6
So while I wait to figure out my rear end issues
Dec 29, 2017
2,232
1,625
133
Long Island, NY
I got some cheap PBR dual piston GT calipers on eBay. Refinished them,
and will rebuild pistons and seals before they go in. There’s some deals out there if you’re patient!
Reactions: Creomod
Habu135
Advanced Member
Jan 10, 2019
790
487
73
40
California
'03-'04 Terminator brakes are fairly inexpensive and this path has been blazed by MANY before you. I'd spend the little bit extra. You won't be disappointed.
africansnowowl
82
36
28
37
San Antonio
You can use your old calipers to get the core charge back if you buy new calipers for a 99-04 GT... Thats what I did. Ended up costing like $100 total with new brake lines and the adapter fitting.
Reactions: Noobz347
revhead347
Apparently my ex-husband made that mistake.
8,710
1,412
214
41
Acworth, GA
They make a 5 lug rotor that bolts right up. That's the cheapest and easiest way to go.
Kurt
africansnowowl
82
36
28
37
San Antonio
They came with the brackets. I did have to grind a little bit off the spindle though to fit the 99-04 calipers. Nothing major at all. Took like 5min per side. It’s obvious what needs to be grinded when you go to put the caliper on the bracket.
Or the 94-98 calipers fit with no grinding, but the 99-04 ones are the twin piston style. They are debatably better.
Admin Dude
Jan 4, 1985
30,324
11,869
234
Box behind Walmart
www.stangnet.com
That's pretty sweet. I had to source my brackets elsewhere. Do you happen to have the ordering and part info for the set you got with brackets?
Rdub6
Dec 29, 2017
2,232
1,625
133
Long Island, NY
I think he used sn95 spindles and calipers, but used his old calipers to return as the core when he bought the sn95 stuff. But I could be reading it wrong.
