I have an 88 GT. The intake has been changed and in the process someone added rubber fuel hose to the area between the fuel rail and the frame rail on the passenger side. Its just clamped on with hose clamps..yuck. So I pulled it off to see what I had to work with and it appears they cut the factory plastic line right about where it meets the metal line on the frame and slid a rubber hose over it. Any idea how to repair this without replacing all of the lines? Is there some GOOD way to connect a union or something to the metal line ir the plastic line (I think there is like 2" left). I dont like the compression fitting idea much. Does russels or someone have a compression type fitting for this area? Basically on the supply line they cut off the quick connect I think. HELP. [email protected]
