fuel pump not coming in with key switch, injectors with 2.30 volts, started when I purchased a megasquirt 2pmp, installed , started car 3-4 times, then pulled car out of garage to wash, water hose busted so went to back car back inside, would not start, I installed new key switch, ECM relay, fuel pump relay, still nothing, sent computer back to megasquirt, they said had a diaode installed backwards, I installed another used dash, ECM and engine wiring harness, after megasquirt repair car still wouldn't start, need some advice... Thanks Scott...
