Fuse 47?
CrazyChick08
Hosford
Having issues with the car ever since I got it smh. I noticed fuse 47, that controls a lot of different things, keeps blowing when the key is turned and all the dash lights and fuel pump comes on. I have a lot of codes reading and I read that all the codes go to fuse 47, so I'm not sure what to do at this point. No mechanic can figure it out
  • Sponsors(?)
Thread starter Similar threads Forum Replies Date
T 08 Mustang GT popping fuse 47 2005 - 2014 S-197 Mustang -General/Talk- 0
nickyb Electrical ? Blowing fuse #6 on my daily. Fox 5.0 Mustang Tech 4
M 93 fox body 5.0 with no power going to 20 amp circuit breaker at fuse box. HELP PLEASE!! Fox 5.0 Mustang Tech 1
Creomod Electrical Tachometer inline fuse wire? Fox 5.0 Mustang Tech 11
D 99 cobra engine fuse box wiring loom 1996 - 2004 SN95 Mustang -General/Talk- 0
W 67 mustang fuse block 1965 - 1973 Classic Mustangs -General/Talk- 4
V Electrical #8 fuse power draw SN95 4.6L Mustang Tech 0
L Electrical Voltage on GEM high power fuse terminals with fuse removed. SN95 V6 Mustang Tech 0
F Electrical 2003 Mustang GT - Brake and Blink Fuses Blow SN95 4.6L Mustang Tech 7
S Electrical Horn keeps blowing fuse and radio not working Fox 5.0 Mustang Tech 2
H Blowing relay fuses 1994 - 1995 Specific Tech 4
V 1994 radiator fan fuse question 1994 - 1995 Specific Tech 3
B Battery terminal fuse 2005 - 2014 S-197 Mustang -General/Talk- 6
Harveyj1965 Fuse box swap 13 + 24 is the missing link The Welcome Wagon 1
Harveyj1965 Hello my name is Harvey my question today is under the hood fuse box I have a 2003 mustang GT edition centennial convertible under the hood fuse bo 1996 - 2004 SN95 Mustang -General/Talk- 0
R What are these relays for? I found these by the fuse box. 94 Mustang GT 1994 - 1995 Specific Tech 8
V help fuel pump fuse is starting blow more an more frequent! 32000 3.8L V6 1996 - 2004 SN95 Mustang -General/Talk- 2
Drum4life23 I have a very interesting situation! 06 mustang won’t start unless I remove fuse HELP! 2005 - 2009 Specific Tech 4
E Fuse 39 2003 1996 - 2004 SN95 Mustang -General/Talk- 1
A Switched fuse 2005 - 2009 Specific Tech 0
KevinV What fuse is the power lumbar on, 93 GT. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
wolfheads Fuse keeps blowing 1994 Mustang GT 1994 - 1995 Specific Tech 3
wolfheads 1994 Mustang gt convertible fuse box 1996 - 2004 SN95 Mustang -General/Talk- 0
wolfheads Fuse box diagram 2005 - 2014 S-197 Mustang -General/Talk- 0
rabidscoobie Backup Lights Fuse Blows??? 1996 - 2004 SN95 Mustang -General/Talk- 3
M What years can use the same fuse box? 2005 - 2014 S-197 Mustang -General/Talk- 0
D 02 GT convertible fuses or gremlins?! 1996 - 2004 SN95 Mustang -General/Talk- 4
E Low voltage at fuel pump fuse SN95 V6 Mustang Tech 4
7 Electrical 1968 6 cylinder coupe fuse panel. Classic Mustang Specific Tech 2
M Electrical 85 tachometer keeps blowing fuse Fox 5.0 Mustang Tech 2
Harveyj1965 Fuse box under the hood has power w the ignition off 1996 - 2004 SN95 Mustang -General/Talk- 11
R Electrical Need Fuse box help Fox 5.0 Mustang Tech 6
N Fuse Box Replacement 1965 - 1973 Classic Mustangs -General/Talk- 2
K Electrical Help! 94 GT lost speedometer, radio, clock. All fuses are good 1994 - 1995 Specific Tech 0
N Wires at fuse block? 1965 - 1973 Classic Mustangs -General/Talk- 0
STEELTHUNDER foglights blowing fuses Fox 5.0 Mustang Tech 17
O Blowing Fuse for Instrument Panel Lights 1996 - 2004 SN95 Mustang -General/Talk- 1
Alley Oop Electrical fuse for 130 amp upgrade? Fox 5.0 Mustang Tech 16
C Dashboard lights not working.Need fuse box diagram 1996 - 2004 SN95 Mustang -General/Talk- 4
J Electrical 1992 gt horn not working Fox 5.0 Mustang Tech 2
M Electrical car is possessed please help was supposed to leave for a 1200 mile trip tody Fox 5.0 Mustang Tech 3
A 1999 V6 Radio Won't Work 1996 - 2004 SN95 Mustang -General/Talk- 6
90Hatchback Electrical Viper 3400v alarm blows fuse with 5-wire door lock relays Fox 5.0 Mustang Tech 26
smokin95vert Electrical Fuse box help Fox 5.0 Mustang Tech 0
G No start, just a click in fuse panel. Fox 5.0 Mustang Tech 4
GT1966 Cig Lighter circuit / Fuse blowing 1966 1965 - 1973 Classic Mustangs -General/Talk- 2
lawd..hammercy S197 05 GT Radiator Fan Fuse Block Repair 2005 - 2009 Specific Tech 0
8 Electrical 95 Mustang GT - Engine wont start after Changing Fuse 1994 - 1995 Specific Tech 3
R 1994 GT - Need Location of Fuse for speedometer, dome light, hood light, pwr mirrors 1994 - 1995 Specific Tech 2
M Electrical 92 GT Convertible - Fuse 13 Continuity Testing Question Fox 5.0 Mustang Tech 33
