Keep in mind that circuit breakers must be de-rated from a fuse.120-125 amps. A circuit breaker would be ideal.
You didn't read your own chart, degC, NOT degF.
That table is not applicable to DC current in engine spaces .
It's for AC conductors in a raceway with all kinds of caveats in the notes.
https://www.westmarine.com/WestAdvisor/Marine-Wire-Size-And-Ampacity
4AWG is rated for 136A.
As a former rocket scientist, I can tell you this is what you do & what works. I designed all kinds of DC power supply systems for DoD-DARPA.
If you can find marine grade wire, it's usually the best. Some stereo shops use it, too.I'm big on safety. I'll go with a quality 4 gauge wire and a quality 125 amp fuse. Thanks again.
The chart is an excerpt from the standards for marine construction, American Boat & Yacht Council (ABYC), Std. E-11, Table IV-A, the marine equivalent of the NEC (National Electrical Code). The 160A is for 105degC rated insulation, which my marine grade wire is. It's printed on the insulation & the lugs were factory soldered.I am by no means a rocket scientist, but I can tell you that the insulation on the wire is going to be a limiting factor...
I have never worked on rockets or boats; only aircraft and automobiles, so those are boundaries of my experience with things that move under their own power.The chart is an excerpt from the standards for marine construction, American Boat & Yacht Council (ABYC), Std. E-11, Table IV-A, the marine equivalent of the NEC (National Electrical Code). The 160A is for 105degC rated insulation, which my marine grade wire is. It's printed on the insulation & the lugs were factory soldered.
https://www.paneltronics.com/atimo_s/news/E11Excerpts.pdf
4 gauge about 7 feet long.
Just curious your routing that required a 7' cable. Mine was like that when I ran it over the the radiator support on a previous installation. I later re-routed the cable running it underneath along K member. The new cable including the fuse block and extension from it was less the 4' in length. The shorter cable will perform better with less amp loss at the load side.
