- Oct 2, 2016
- 67
- 5
- 8
When I drive my 92 331 stroker around with the heat off, it gets to 210. But as long as my heater is blowing it stays around 185-190. Any ideas of what would cause this.....
It's a 15 inchI'd suspect the 12 inch single fan. The heat adds an extra fan.
I'd advise you to go on ROCKAUTO and order a dual electric fan assembly for a Ford Contour from the late 90s. Or a Mercury Cougar v6. Those dual fans keep my turbo car cool.....too cool if they stay on constant.
Take the radiator cap off when it cold. You may have to squeeze the lower hose a couple times to see the top of the first one or two tubes, crank it up and let it get warm and watch as the thermostat opens water will start to flow, as you raise the rpms the water will flow faster and rise up so be careful.Don't know why it posted 3 of them. Sorry for the mess up.
How would you check the flow of the rad?
My hoses feel good when it's hot and they are in pretty good shape
