Going Low or Going High?
maisonmays22
34
Amarillo Tx
Looking at a few of yalls tunes some of you have ignition set at going low and some have at going high. My car is a 1988 mustang GT with stock ignition set up. So which is it? In the notes it says this is a crucial selection because it can burn your coil.
  • Sponsors(?)
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
9,759
5,808
204
31
Hillsborough county
It depends on the system. The following information assumes a TFI system.
The mspnp2 uses a tfi circuit built onto the break out board. These get set to going high.
A Micro uses the wled output to drive the tfi, these have a pullup installed. This get set to going low.
Bottom line is if you have spark advance working on a tfi your settings are correct for the application.
