got car running again! with vid
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
was off all last week on paid vacation.
put my new battery box and relocated battery, installed 255 lph pump and mounted up my ignition box, car ran awesome and then a few mins later a freeze plug popped out ( old ones rotted out and i replaced them with expandable plugs from under the car) they fell out so i pulled the motor and trans. to get some nice bras plugs and install them the best way so they wont leak, i also installed a RAM powergrip HD clutch, also replaced oil pan gasket and rear main seal.
luckily i was on vacation so i did all the work while i was off last week and the downtime was only a few days lol.
heres a small vid of me rolling down the highway, car is runnning its best right now. the ignition box really made a differece. i was running stock ignition with .025 gap and the car kept breaking up real back over 5k. now with the summit box i am running .040 gap and the car runs smooth all the way until i shift. really was suprised at the difference the ignition upgrade helped.
just need to do some small tuning things but overall the car drives very well and i could take it to the track now just need some tires.
car is running around 11.5 AFR and 18* total timing at higher rpms with 91 octane. car runs killer on the street.
hoping for 11.50s or so. also considering buying soem race fuel and trying to tune for that, adding more timing and etc to see if i can really run quick on some good gas at the track.
supercharged 91 stang cruise - Video
let me know what you think. hehe i short shifted into 3rd real bad. its hard to drive it one hand and one on the camera..
i really hate not having the correct speedo gear, they dont make them for 3.90s so my speedo is actually around 10 mph slow and makes the car look slower haha i am considering going to a higher gear like 3.55s or something soon hopefully so i can get a gear to match that for sure.
also want to get a nice tachometer. last season i thought i was about the hit the rev limiter, tach showing 6200 and i was actually turning 5700.
in the vid my tach reaches around 6k a few times but i was also logging the car at the same time and my logs never really show anwhere slow to 6k maybe around 5300-5500.
so i dont know how far off it it, maybe i can pick up some performance with an accurate tach, i may not be turning it as high as i should. the car never stops pulling lol just shift according to the stock tach.
  • Sponsors(?)
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
shoot its hard to say how much time i actually have invested in tuning.
i got the tweecer a few months ago, been messing with it off and on.
the main thing is just getting the MAF transfer to accurately represent what is actually going into the engine, then its a matter of dialing in the inj slopes and everything else seems to fall into place easier.
i would guess about 10-15 hours of actual tuning time and this is learning from scratch, have had some help from a guy i have been emailing and have learned alot. no tuning expert yet lol but i understand most everything.
still have some small stuff like idle and etc work with... just getting everything dialed in perfect but overall the drivability and performance is 10x better than having no tune.
92GreenGT
PEAT
2,085
33
Big Stone Gap, VA
www.fullthrottleforums.com
What way did you go about dialing in your MAF curve? Sorry to go off topic in your thread but I'm working on the samething at the moment.:nice:
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
starting off i found the slopes and BP and inj offsets for 42s per FRPP's specs
i was just running the "norm" people suggest to run and i had some problems getting things working good.
tried the ford specs out and loaded up the generic pro-m42 maf transfer from EA
my actual meter is the "blower tuned" meter.
and from what i have found, the low end of the curve is pretty close to the generic transfer and the high end is way off.
the "blower tuned" MAF artificially adds fuel by having insanely high airflow values on the big end, to fool a stock untuned EEC into dumping more fuel into the engine.
for my combo is seems to work fine, i may be losing a little bit of resolution on the top end of the curve. my engine is only reaching around 4.2 volts on the MAF with the current setup. theres a few points on the curve i am not even closer to reaching.
according to most people about 4.5v is about perfect. if you start getting higher voltages your maf is undersized. but i have talked to some people (including Pro-M) and they said me reaching 4.2v is fine, its not horribly oversized and it gives me room to grow later if i want
anyways i have been logging the car and running the MAF tool in EA, i have a WB so my adaptive strategy is disabled. so calculations are made solely from LAMBSEs and my AFR readings
first few logs and maf tweaks have made good improvments, the majority of the changes were on the big end. its getting closer. its at the point now where i am going to start tweaking one point at a time, so i dont start chasing my tail, i am told EA will tend to overshoot on the calculations.
92GreenGT
PEAT
2,085
33
Big Stone Gap, VA
Very nice, can you send me a PM with the #42 injector info you have that worked best for you? My car idles awesome and all that, drives fine but it's just rich throughout the curve. I have a wideband as well, I haven't had time to mess with it, more of tinker with it so I'm going to have to more effort into it or let someone else tune it.
Sorry for the hijacking btw.
Thread starter Similar threads Forum Replies Date
blackstangt Finally Got My Car Running Properly (lessons Learned) Fox 5.0 Mustang Tech 1
R got my car to run KOER now................ Fox 5.0 Mustang Tech 5
5.0Torx OK, got the car running. But it doesnt run well. Fox 5.0 Mustang Tech 20
D Finally Got the Car Running Again 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
8 just got car running but temp gauge isnt working need wiring help so i dont blow it! Fox 5.0 Mustang Tech 11
B Got car running good, but one more problem 1994 - 1995 Specific Tech 4
cenok is family got my car running! pics and vid. 56k warning 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 15
90_Red_LX Finally got the car running! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
woodyy24 Finally got the car running (vid) 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 46
W Got a question on rough starts right after car has been running Fox 5.0 Mustang Tech 1
R Done an H/C/I and got car running..but seems low on power? Fox 5.0 Mustang Tech 5
K Got the car running today!! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
2L8ULUZ2 Got the car up and running again. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
TweekedGT Got the car running!!!! 1996 - 2004 SN95 Mustang -General/Talk- 4
N Finally got the car to start but does not keep running 2.3L (N/A & Turbo) Tech 2
Hoytster Got the car running today 1994 - 1995 Specific Tech 7
OrangeMustangGt Just got my car running!!! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
N8Miller jrichker: got some updates on non running car, it runs... but help! Fox 5.0 Mustang Tech 10
mustang95gt got car running & now Check engine light 1994 - 1995 Specific Tech 3
OinkAodeOink Finally got to run my car.. 1994 - 1995 Specific Tech 26
BlueOvalStangGT HEY CAR IS RUNNING!! Got a few problems, overheating, oil leak,HIT 5#'s!!! 1994 - 1995 Specific Tech 9
Wrath Well...at least L8ON got 1 car running this year... Regional Forums and Event Information 5
OrangeMustangGt Just got car running: Headers glow red!! Fox 5.0 Mustang Tech 14
93 teal terror Just got car dyno'd...runs a little rich and not as much hp as expected. Fox 5.0 Mustang Tech 15
C Hi guys i just got a 2003 mustang gt 4.6 how do check kow it the car has pi heads SN95 4.6L Mustang Tech 6
Twitch'n Twitcht4life My P.M.S. got stolen from my car. Hey 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
J Cheap fix for front bumper that broke off when I got the car stuck in a ditch. 2015+ (S550) Mustang -General/Talk 4
TNAVY Finally got a Cobra (my dream car!) The Welcome Wagon 1
G Paint and Body Spring is finally here and got the car cleaned up. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
Noobz347 The Car Cover Thread - What You Got? Mustang Sound & Shine All 55
R Car Got Water In It !! 2005 - 2014 S-197 Mustang -General/Talk- 3
B Just Got A Used 89 Gt As A Project Car The Welcome Wagon 2
robert fugate Finally Got The 351 In The Car 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 18
Mattstang04 Got The Car Dyno'd Today 1996 - 2004 SN95 Mustang -General/Talk- 22
Ant85 Anyone Ever Got Drunk And Ordered Car Parts? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 17
J nice day so i got the cars out yesterday.. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
SonicStangGT Got my car tuned finally. 1996 - 2004 SN95 Mustang -General/Talk- 14
CarMichael Angelo Need Heater Control Cable For 89 Car, Who's Got One? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
demented22 Car Got Stuck In Rev Today??? 1996 - 2004 SN95 Mustang -General/Talk- 8
MY 85 GT Got my car Back!!! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
Modular2v Got the car back from paint today :) 1996 - 2004 SN95 Mustang -General/Talk- 15
rbonella Got my car out for spring and guess what I found? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
9 how to tell if my cars got pi heads or just the up graded intake 1996 - 2004 SN95 Mustang -General/Talk- 7
8 got a new car 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 19
hotstang_46 Got My Car Back, New Paint, Saleen Kit, Etc 1996 - 2004 SN95 Mustang -General/Talk- 19
LarsD Got my new 255L pump in, but car won't start Fox 5.0 Mustang Tech 4
cardudeusa Just got my car back from getting painted! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 31
94GTLaserRC Got My First Mod (before car)!! 2010 - 2014 Specific Tech 5
C My car got some ink!!! 1965 - 1973 Classic Mustangs -General/Talk- 3
G Guess What? The Engine Guy Got His Car! 1965 - 1973 Classic Mustangs -General/Talk- 21
