So I had my GT-40p heads rebuilt and I told them my cam is:
Lunati Street/Strip Camshafts 20350514
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
Valve Lift with Factory Rocker Arm Ratio: 0.500 int./0.510 exh.
So they rebuilt the heads and put in new springs.
The guy I told the cam info to, told the guy that rebuilt the heads, the cam was about 500 lift.
The guy I spoke to said they're fine and the person who did the heads, who is also the owner, said its possible I might be making contact with the seals...
Needless to say after spending $590 on a basic rebuild I am pretty agitated if I now need to change the cam or maybe change the springs.
They used these springs: Comp 942-16
Outside Diameter of Outer Spring (in): 1.437 in.
Coil Bind Height (in): 1.125 in.
Damper Spring Included: Yes
Spring Rate (lbs/in): 339 lbs./in.
Inside Diameter of Outer Spring (in): 1.039 in.
Am I good with these, or do I need to consider another option?
Thanks in advance for any help
