GT40P heads, Cobra intake, full exhaust, C&L MAF- only 196.70 RWHP on DYNO!!!!!- HELP
Lxpony
355
central mass
geocities.com
Ok, so brought (what I thought was going to be a beast) to the dyno this morning - dynojet- and got a big surprise! MY CAR HAS NO BALLS- I thought for sure my car would have more balls then this-
The intial reaction by the guys there was that the car was running way lean- I was the only non- blown car there so I was the leanest but because I was N/A- I went home and reviwed some info and confirmed that a N/A "chemically perfect" stoicometric ratio is 14.7:1. Well - all the blown guys were around 11:1 and there I was leaner then Mary Kate Olsen! based on what I see from the A/F ratio off my slip I am right at around 14.7:1 so where is my power?
so I took photos of 2 plugs- #1 and #5 and they look fine to me- they have about 500 miles on them- please take a look at plugs and time sheet....
I dont think that I am lean- I have 24# with matched C&L tube, stock FPR and 190 LPH pump- I guess my car stock put out about 170 at the rear wheels (pathetic as hell).
my only purpose of the dyno was to baseline prior to my vortech next month but now I an thinking I should go with the S trim and not the SC since I am about 50 HP behind where I thought I should be-
the Gt40p heads are bone stock as is the intake- shorty headers and C&L 76mm are the only real engine mods...... but I swear I thought some guys with the same combo where making close to 300 rwhp??? Do I suck? should I put a brick on the gas and drive it over a cliff?
The dyno slip are the same but with and without flash on my camera
PLEASE HELP!
  • Sponsors(?)
SmockDoiley
1,591
San Diego, CA
Visit site
Yes, that is the ideal calculated perfect A/F ratio, but it doesnt work in real life. And can actually be bad if running bad gas, pulling something, hauling ass up a hill and so on. For a nerd mobile it may be good, but we hot rodders need to tune for hot rodding which means you need to bring that A/F down to around the 13/1 area. Also, what is your timing set at? Running a little richer not only allows for more gas but allows for more timing which means more power. You could see a huge spike in power if you bump up the pressure and raise the timing if your set low right now. Also, get a leak down test on the motor to make sure its healthy. All the parts in the world will do no good if the motor is crap. As for your mods, the dyno is showing about 230 at the flywheel which if all you have is gt40p stock heads, CAI and headers, this may not be too bad. Do you have a full exhaust or just the headers? Your car really needs exhaust and an intake to really take advantage of heads or a supercharger. Dont be too disappointed.
Grn92LX
Fidanza Man!
6,754
42
129
New York
Visit site
Idealy you want a 13:1 a/f for a n/a car, but the low-mid range can be a little leaner. Fix your issues before installing a supercharger. Do you have a FP gauge? If so, what is FP doing at wot, is it dropping or steady @ 39psi? In your case, an afpr could help, try 45psi and see what happens. Are you running the right spark plugs for the P heads? Bad fuel filter?? Check the basics man, clean your maf wires. Maybe try disconnecting ther battery overnight to fully clear the KAM, then put it back on and go for a drive and wot blasts. Maybe the eec can adapt your fuel curves.
Lxpony
355
central mass
geocities.com
my timing is set to 10 degrees (stock)- so bumping timing up would afffect FP?
If getting a AFPR is the answer that I would be happy but I thought that if I bumped up FP by 3-6 PSI then the compter, via the O2 sensors, would detect this and lean me back down to the stock FP? Is this not correct?
I have a high flow H-pipe with 2 cats, shorty unequal headers, and flows.. for exhaust
Grn92LX
Fidanza Man!
6,754
42
129
New York
Visit site
Yes, sometimes that is the case and the eec will adapt out the FP changes by changing the injector pulsewidth. In your case, I dont think it will do that as your way off in your a/f. Timing has nothing to do with FP. Try running 14-16* timing. Are you using a cobra/explorer manifold? Assuming you have P heads and a cobra manifold with the typical bolt ons, with a good tune you should have around 250rwhp..
Lxpony
355
central mass
geocities.com
I do have an electric FP gauge- it was steady at just under 40 PSI at WOT which is what is supposed to be I know.... maybe I will go with an AFPR to start-
I am running plugs that per Autozone's computer are meant for those heads- Motorcraft platnums, fuel filter has approx 2k miles on it- fuel pump is 1 month old and about 200 miles on it- 190 LPH unit
battyice
153
West Chazy, NY
The computer can change the injector's pulse width, but can't really change your fuel rail pressure. Many people find extra hp by installing/tweaking an afpr; and even if it is not the source of your problem, it will be a neccessity down the road if you want to do more modifications.
Also, have you checked your car to see if it is throwing any codes? That would be worth a shot IMHO; you need to make sure your O2 sensors and whatever else are functioning correctly.
SmockDoiley
1,591
San Diego, CA
Visit site
Thats why you ditch the stoich and go to a richer A/F around 13/1. You'll be much safer and make more power. As for your mods, you are low if you have a cobra intake and full exhaust. But again, bump up the timing and FP. Timing has nothing to do with FP. Trust me if your timing and fuel pressure is stock, youll be amazed how much power youll make if you adjust those.
Lxpony
355
central mass
geocities.com
ok then a AFPR is the next purchase- no check engine lights but I realize that doesn't mean it is not throwing codes- I will have my mechanic buddy plug into the socket by the driver side rear strut tower to double checkI will wait for the SC until I get my AF back under or close to 13
o2 senors are new- have about 3k miles on them
Ranchero5.0
The Voice of Reason
Jan 1, 1999
5,306
48
Hagerstown MD
You need a decent fuel pressure regulator. The fuel pressure adjustment acts like a power valve in a carb. If it's too low the car won't pull very well, and if it's too high the car loads up during a pull. The puter runs set tables during WOT and doesn't care about the o2 readings, but will lean itself out during non WOT situations.
When I bought my '93 the fuel pressure was set at 38psi without a vacuum source and they were using the FMU to raise the fuel pressure. I had no 'power valve' function and the car fell on it's face and went lean before boosting. Now I run it at 45psi with vacuum and the fuel runs about 40psi at cruise speeds and the A/F is happy.
Jamie
nito88stang
2,012
Fullerton, California
TIMING add more timing, if your car ends up liking 16* of timing then thats 6* of timing you need. Thats like 20 hp left on the table if not more. Play with the timing, and just listen for pinging.
hllon4whls
BANNED
2,567
46
Covington
I am with these other guys. You just need to tune the power out of your car. When I first ran my car, I ran 12.50's. With a little tweaking, it went 11.96. With a better carb, locked out dist and some more tuning, 11:60's.
Remember, the trick is in the TUNE!
kystang1889
199
ky
Visit site
also if you are running 24# injectors what size mass air to you have if you have the stock mass air that is hurting you too, you need a mass air cal. for the bigger injectors also what cam are you running, you need a nice size cam to really open up those heads
Schlodes
Stock cam isn't that bad and would work well with a 1.7 rocker. Bump the timing like everyone else is suggesting it will make a good difference. Does the car have the stock clutch fan? Ditch it. How about accessories? Smog pump still on? I know its only like 2 HP to spin it, but, every little bit helps. I've never had luck with platinum plugs really... maybe try a Ford Motorcraft stock heat range plug got the P heads, gapped at stock specs??? What throttle body do you have. With good heads and intake the stock T body could be a bottle neck. :shrug:
Is it an AOD or 5 speed. [didnt read thorugh reply..]
gt90stang
568
Visit site
First off is your TPS adjusted correctly and is it actually going into OL or WOT operation. In WOT operation the PCM uses tables to determine the AFR from trim values learned while driving. In my datalogs with Tweecer RT the AFR is pretty close to what is in the tables. For the stock PCM the tables are shooting for 12 to 12.5:1 at OL or WOT conditions and this is what my datalogs have shown. I have leaned mine to 13 to 13.5:1 and notice a definite improvement in performance.
If you vehicle isn't getting into OL or WOT then it would normally run at Stoich in closed loop operation.
Something is out of cal. in your setup and unless you can datalog what is going on your just shooting in the dark. I use Tweecer RT and a WB02 to tune.
Good Luck, Don
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
stangnet.cardomain.com
I just skimmed through some of the replies, but I wanted to reply when I saw the dyno chart. I've seen really spikey curves like that before, and I think it usually indicates an ignition problem.
I didn't see anyone else mention it, so maybe I'm not even close...???
Lxpony
355
central mass
geocities.com
guys, in an attempt to fatten up the A/F I put my 19# C&L tube back into the mass air meter and the car is running as well as it did with the correctly calibrated tube. so atleast I fattened up the A/F a little bit with that correct?
Thread starter Similar threads Forum Replies Date
W GT40P heads Cobra intake gasket??? Fox 5.0 Mustang Tech 4
J Gt40P Heads Spark plug Gap. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
G 289 with GT40P heads 1965 - 1973 Classic Mustangs -General/Talk- 8
P Engine 90 gt40p heads EGR/Thermactor question Fox 5.0 Mustang Tech 8
Ian Ranchero Will these headers fit Gt40p heads 1965 - 1973 Classic Mustangs -General/Talk- 9
T GT40P Heads Exhaust 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
S gt40p heads 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
J Need help 1995 5.0 roller stock lower e303 gt40p heads 1965 - 1973 Classic Mustangs -General/Talk- 0
lxhatch91 gt40p head piston/valve clearence 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
T Longtube headers that fit gt40p heads 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
K Fox Plug gap for gt40p heads 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
J GT40P heads... good deal? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 18
PakstinN Engine Ported Gt40p's?? Fox 5.0 Mustang Tech 15
GalacticPonage Engine Where To Get Gt40p Heads Fox 5.0 Mustang Tech 6
P Gt40p Heads 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
M Pushrod Length On Gt40p Heads Fox 5.0 Mustang Tech 4
M Cam For Gt40p Heads 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
master_bayshin Valve Spring Question Gt40p Heads E Cam 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
O Engine Whats Needed For A Gt40/gt40p Head Swap? Fox 5.0 Mustang Tech 11
DM87GT Gt40p Heads With Stock H.o. Roller Cam Fox 5.0 Mustang Tech 19
XerxesTheGodKing Gt40p Heads + B303 Cam Fox 5.0 Mustang Tech 2
1 Gt40p Head Swap 1996 - 2004 SN95 Mustang -General/Talk- 0
RedGT88 Factory Headers On Gt40p Heads 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 14
G Gt40p Heads Trickflow Spring Replacment Size Issue Fox 5.0 Mustang Tech 0
smilts New Gt40p Heads Quick Questions 1994 - 1995 Specific Tech 10
fivespeedsteed gt40p head junkyard questions Fox 5.0 Mustang Tech 45
Paul Randle Preparation Work For Installing Gt40 Intake And Gt40p Heads???? Fox 5.0 Mustang Tech 2
Paul Randle Can You Mix Gt40p Heads With Gt40 Lower And Upper Intake? Fox 5.0 Mustang Tech 10
bbrewer5 Exhaust Cheap Headers + Gt40p Heads. 1994 - 1995 Specific Tech 17
P Romove Gt40p Heads To Replace Frpp Hyd. Roller Lifters??? Fox 5.0 Mustang Tech 9
bbrewer5 Engine 95 Gt40p Head Swap Valve Noise. 1994 - 1995 Specific Tech 14
f8tlfiveo Gt40p Heads Engine and Power Adder 8
R What Fel Pro Gasket Should I Use With Gt40p Heads? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
sneaky98gt Gt40/gt40p Heads On A 351w Questions Fox 5.0 Mustang Tech 27
f8tlfiveo Gt40p heads with stock springs Fox 5.0 Mustang Tech 2
88LX Explorer GT40P Heads and Intake Engine and Power Adder 10
P Gt40p heads, and GT40 plenum up for sale Engine and Power Adder 0
fivespeedsteed good gt40p head reading, couple questions. Fox 5.0 Mustang Tech 28
foxbodymike87 What cam goes best with gt40p heads? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 16
Eikki GT40P heads, oil pan, camshaft, injectors, fuel rail, pistons-rods Engine and Power Adder 11
darthcual GT40P Head prep Fox 5.0 Mustang Tech 7
lincoln+ford tfs 2 cam and gt40p heads Fox 5.0 Mustang Tech 1
W GT40P Heads Engine and Power Adder 0
J Need help with GT40P or GT40 Heads 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
red-fox GT40p heads and intake? Fox 5.0 Mustang Tech 14
S 302HO with gt40p heads Classic Mustang Specific Tech 10
0 GT40P head swap problems.... Fox 5.0 Mustang Tech 6
M New here..need help after gt40p head swap WHAT SHOULD MY FUEL PRESSURE BE? Fox 5.0 Mustang Tech 4
FordRacing302 Which valve springs for TFS1 cam on GT40p heads Fox 5.0 Mustang Tech 4
tank_567 11.9 with gt40p heads and cam 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
