Heater hose removal
Woody3882
5 Year Member
Jun 19, 2018
84
9
18
Bradenton Fl 34212
I posted this question last week but it disappeared so i will try again....
My 65 mustang has an original 289. I live in Florida so I have no need for heat. I disconnected the heater hoses at the intake manifold and block. I put rubber caps on the water ports. A friend was over and told me that it was wrong to just cap the ports and that I should have put a small hose from the manifold heater hose port to the block heater hose port. He claims it will cause overheating the way It have it.
Does anyone know which is the correct way to delete the heaters hoses
Thanks
You may delete the two hoses going to the firewall...those go to your heater core. I recommend keeping the bypass hose going from the water pump to the thermostat housing as it recirculates coolant and ensures your water pump does not cavitate. You will find, however, that opinions vary and some have deleted their bypass as well...I'd definitely keep it.
Reactions: 1 user
In 65 the factory put a plug on manifold and water pump for heater delete cars but kept bypass hose by thermostat.
Reactions: 1 user
