- Nov 13, 2014
- 26
- 1
- 13
I am having a very odd problem with my cooling system. I had an issue a while back after I did some maintenance (Changed oil) and ended up braking my radiator cap(it still fit so i put it back on). I drove home that night and noticed that the car was running much hotter than usual while stopped but cooled a little when I was driving. Once I got home I heard a noise from the engine bay, after inspection I could hear the radiator fluid boiling in the overflow tank. The pressure built so high that the plastic top popped off of the overflow tank and steam bellowed out of it. I never figured out what the issue was.........
Fast forward to today, I replaced the radiator, and thermostat and refilled the radiator with water wetter and water then started it up. I left the radiator cap off to try and get out all of the air bubbles, as the car ran the fluid began filling up the overflow tank then flowing out of the radiator top. After a few minutes of that it began to steam then started spewing fluid out of the radiator top.
I'd like to add that before I changed the oil and broke the radiator cap I had no heating issues that I was aware of.
My next guess would be a bad water pump. Someone help!!! This thing is driving me insane.
