I checked the starter by removing it again and using the battery cables to make sure it was working. Reinstalled after autoxloo and still has the same problem. I have an engine warning light, all the extra power, a fuel pump primer, but turn the key and there is absolutely no noise. I'm going to check the wiring with a multimeter, but I'm at a point where I think it could be a key issue or a security issue. You can test the control side of the relay to see if the TIPM is commanding the starter, or you can jump it and get the start to turn over to see if starter is the problem. Make sure you know what you are doing here so you don't mess up a computer but it's the best way to break the starter system in pieces.
