Help With Engine Codes Car Code 172 HEGO (HO2S) sensor fault/lean
DJiCE
117
Bloomfield, NJ
badbiosflash.com
Need Some help to deciper the following codes:
I get the Following Fault Codes For Sensors ( I tested it with getting engine to running Temp so I believe this what causes these codes)
CODES: 116 - Engine coolant temperature higher or lower than expected
636 - Transmission Oil Temperature higher or lower than expected
NOW CODE STORE IN MEMORY
CODE : 172 HEGO (HO2S) sensor fault/lean
What does this mean?
Here are my symptons:
When cold it trembles a bit, idle not smooth
After it warms up ~ 5 to 10 mins engine runs smooth.
Durring the cold start when I accerate egine bogs a bit, like it can't breathe.
Something weird that never happen is I see water exiting my exhaust pipes.
I also notice my high pressure line to fuel rail was comming loose so I re tighten it.
Any Help much appreciated.
  • Sponsors(?)
HISSIN50
SN Certified Technician
27
129
Check the ECT voltage when the engine is cold and then once at temp.
When at ~50*F, the sensor (KOEO) should show about 3.50V (dont test it below 50* - the results are not accurate).
At 180*F, you should see about .75 V.
For both tests, you dont need to have the car running if you're worried about moving engine parts. Just have the key on.
The ECT code can generate an O2 code, so the ECT is the place to start.
DJiCE
117
Bloomfield, NJ
badbiosflash.com
OK, How easy is it to get to the ECT sensor? location on the manual says it's at lower intake. Included Pic. Laso found instructions on testing it at:
TESTING ECT SENSOR
Since it was nice out today I cleaned the maf sensor and re oiled the K&n Filter.
Still drying the filter so couldn't test if that helped.
tomorrow hopefully I will test the ect sensor
HISSIN50
27
129
My testing method incorporates part of your vehicle's wiring, which the resistance testing does not. You can do the resistance test but the ECT circuit can still be bad. If testing it plugged in, you atleast can see that the thermistor carries a load and unless the wiring from the ECT to the EEC is bad, it should be copacetic.
The chart in your link shows more graduations of the voltage values (earlier I only provided the two most useful ones to me).
Good luck.
Chythar
2,217
43
98
48
West Los Angeles, CA
If your ECT is bad, the engine will likely run rough - the computer adjusts fuel based on the engine temperature. Hissin's testing technique won't lead you wrong, helped me diagnose a bad ECT sensor. The sensor is screwed into the front of the metal coolant line that leads back to the heater core, pretty easy to get to.
Don't know much about diagnosing the transmission code, has the transmission been shifting different as of late? Is the fluid level low?
Water in the exhaust is relatively normal, it's just water in the air condensing in the hot exhaust pipes. Since you're running lean (code 172), the exhaust will be hotter than normal and you'll get a bit more water. It's normal, nothing to worry about.
DJiCE
117
Bloomfield, NJ
badbiosflash.com
Ok I did the Resistance test, but I was not able to get any voltage from the sensor only resistance.
This is how I tested it for Voltage and resistance.. With key on position and disconnected harness I hook up volt meter and was able to get resistance but no values for voltage the 2 pins on the sensor.
Do I get voltage from the sensor pins? how do I test voltage?
here are my results:
cold got 58.1 Kohms 0 volts
then a bit warmer 24.3 0 Volts
warmer 7.9 Kohms 0 Volts
Near "N" Normal 3.3 Kohms 0 volts
Trans runs great, level is fine and very clean.. That error code may be because I ran the code scanner at cold did not warm up car?
99FiveOh
2,050
18
99
J-Ville, FL
Ok, you're not going to get ANY voltage from the sensor if your car isn't giving it any, meaning, you need to plug the sensor back up and probe the wires.
DJiCE
117
Bloomfield, NJ
badbiosflash.com
UPDATE: 2-9-09 Ran code reader this time at normal operating temps:
Now I Get NO SENSOR ERROR CODES:
CODES 116 - Engine coolant temperature higher or lower than expected - GONE
636 - Transmission Oil Temperature higher or lower than expected = GONE
BUT NOW HAVE THE FOLLOWING CODES STORE IN MEMORY:
CODE : 332 Insufficient EGR flow detected - NEW CODE
Should I replace the EGR VALVE?
99FiveOh
2,050
18
99
J-Ville, FL
Take the EGR off and check the rubber diaphram, they crack alot of times then won't work period! I'm glad I live in a state that doesn't check for them.. mine will be coming off as soon as I score a fox TB and cable!
HISSIN50
27
129
Also make sure you didnt remove or break the vac line to the EGR, and that the position sensor is plugged in. When a code comes out of nowhere after not having been there, a lot of the time it's something that was disco'd or broken during other work.
For a quick EGR valve test, you can simply let the car idle and disconnect the vac line to the EGR. Put a spare vac line on the EGR vacuum nipple and apply about 6" of vacuum to the line (I just use my mouth, but a Miti Vac works. Guys, insert your jokes here. Ha ha, I said insert too). You can see the diaphram move and the engine will start to stall. Be careful while working around a running engine and all that.
DJiCE
117
Bloomfield, NJ
badbiosflash.com
I finish testing the ect sensor,
here are the results (Voltage):
Disconnected connector and test for voltage got 3.5V
With connector plugged in I got 1.61V (Engine cold)
"" "" (Engine Mid Warm) .78V
"" "" (Engine at normal temp) .12V
So far I cleaned MAF, used Chevron Fuel Injector Cleaner it's running a bit better but not perfect.
I also cleared the codes and will see if they pop up again so far no check engine light.
Next on my list is replace spark plugs and check for vacuum leaks.
HISSIN50
27
129
How did you do voltage testing with the ECT disconnected? Was this the 5 volt feed into the sensor's pigtail? If so, you have an issue.
You can see that all of your readings are phase shifted high. Figure out why your VREF is only 3.5 volts instead of 5.
DJiCE
117
Bloomfield, NJ
badbiosflash.com
Yes I got the 3.5V with the pigtail disconnected and probed the socket connector with key on position.
Rest where with the sensor and pigtail connected and back probe the connector for voltage
Will have to re-test and make sure, thanks once again.
Chern_889
86
Lumsden, Saskatchewan
I had the same lean code on both the left and right banks when i first bought my car, finally narrowed it down to an extremly dirty maf, cleaned it and codes went away, with it also came about a 100HP increase on the seat-of-the-pants dyno
DJiCE
117
Bloomfield, NJ
badbiosflash.com
here's an update after re-testing ECT and Codes:
1st after clearing codes, they cam back two days latter:
SENSOR TEST OK ;>
Code Store in memory: 172 HEGO (HO2S) sensor fault/lean
Now for ECT TEST:
Disconnected connector and test for voltage got 4.57V
With connector plugged in I got 3.71V / 17.1K Ohms (Engine cold)
2.05V / 7.09K Ohms
1.15V / 4.8K Ohms
.77V / 2.9K Ohms (Very Close to Normal Temp)
Now I believe ECT is OK, So can I say problem most Likely Oxygen Sensor?
HISSIN50
27
129
SENSOR TEST OK ;>
Now for ECT TEST:
2.05V / 7.09K Ohms
1.15V / 4.8K Ohms
Your warm-voltage reading looks ok. You cannot take resistance readings with the sensor plugged in.
Run over the rest of the items on your car that can cause a systemic lean issue (vac leaks, dirty MAF, low fuel pressure under demand, etc etc).
Thread starter Similar threads Forum Replies Date
P Help!! Open Injector Circuit Codes SN95 4.6L Mustang Tech 21
J 1985 mustang gt 5.0L carb (M) serial code engine wiring harness and under dash wiring harness 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
S Ran Engines Codes. Help! Fox 5.0 Mustang Tech 1
LoganCT 94 Gt Engine Code 636 Help 1994 - 1995 Specific Tech 0
dz01 Engine Fault Code Help... Fox 5.0 Mustang Tech 36
E Engine Help With Reading Check Engine Codes!! Fox 5.0 Mustang Tech 7
N Engine Codes And Electrical Problems Help! SN95 V6 Mustang Tech 2
golf4283 Engine Code Help Fox 5.0 Mustang Tech 11
2 **NEWBIE** engine codes need help... SN95 V6 Mustang Tech 1
cantbuytime got 3 check engine codes, replaced the parts and still have problems! please help 1994 - 1995 Specific Tech 4
B help with check engine codes please Fox 5.0 Mustang Tech 6
S engine code help! SN95 4.6L Mustang Tech 3
8 engine codes bucking, popping please help! Fox 5.0 Mustang Tech 7
ramair4ta CODE 22 ENGINE LIGHT ON HELP Fox 5.0 Mustang Tech 7
J engines codes please help 1994 - 1995 Specific Tech 3
F Help with diagnosing two check engine light codes? SN95 4.6L Mustang Tech 11
C engine lights codes, please help SN95 4.6L Mustang Tech 14
T Code p0340, sensor replaced, check engine light gone, but car backfiring...help!!! SN95 4.6L Mustang Tech 19
T Help needed on check engine light codes SN95 4.6L Mustang Tech 5
builtPARKtough Help with engine codes Fox 5.0 Mustang Tech 10
R Question About Some Fault Codes Check Engine Light Please HELP SN95 4.6L Mustang Tech 3
Roland69 need engine code help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
E Help w/ Engine Codes Fox 5.0 Mustang Tech 12
H Engine code Help?? Fox 5.0 Mustang Tech 9
Steed93 Need help with engine codes 66 & 87 Fox 5.0 Mustang Tech 1
67stangboy Engine Code help Classic Mustang Specific Tech 10
fvike Engine block code help Classic Mustang Specific Tech 0
8 help me get rid of engine codes... Fox 5.0 Mustang Tech 3
C Engine code 34 help! Fox 5.0 Mustang Tech 2
98stangv8 engine codes help SN95 4.6L Mustang Tech 4
Team801 Rough Idle + 6 Engine Codes **Help** SN95 4.6L Mustang Tech 15
jrichker Help me create the "Surging Idle Checklist" Fox 5.0 Mustang Tech 558
D check engine lite on code reads...help?? SN95 4.6L Mustang Tech 1
M Need help with engine codes 41 & 91 Fox 5.0 Mustang Tech 5
Bobbys97R HELP engine code SN95 4.6L Mustang Tech 6
Bobbys97R HELP engine code SVT Tech Forum 7
deftsound Hey can someone help me with engine codes Fox 5.0 Mustang Tech 0
deftsound HELP with engine codes Fox 5.0 Mustang Tech 5
9 Help! P1151 engine code??? SN95 4.6L Mustang Tech 7
J engine missing out @ high rpms HELP have codes Fox 5.0 Mustang Tech 7
Starscream88 Code 41 "Engine Lean" and car not running right, Help me sort it out! Fox 5.0 Mustang Tech 7
mustanger98 HELP Engine code!!! SVT Tech Forum 6
68GEETEE check engine code P1443 HELP SN95 4.6L Mustang Tech 6
oo7thenova Help with code 31, check engine Pls. Fox 5.0 Mustang Tech 5
2 2000 gt engine ID sticker help 1996 - 2004 SN95 Mustang -General/Talk- 2
K HELP! Nasty Grinding noise coming from center of the engine/ Mustang 06 v6 2005 - 2014 Specific V6 Tech 1
4 Please help my PCM is flooding my engine Fox 5.0 Mustang Tech 11
S Engine 2000 3.8 Engine Swap to 94 SC! SN95 V6 Mustang Tech 5
W 97 Mustang GT Engine Swap (Need Help) 1996 - 2004 SN95 Mustang -General/Talk- 5
K Engine swap help Other Auto Tech 1
