Hydraulic Roller Lifter Install Clearance
GT1966
69
63
Maine
OK, so I have an '87 roller motor in my '66 GT that was built with a flat tappet cam....don't ask why, I have no idea. Well, the flat tappet cam now has one lobe that's wiped-off. I want to go back to a roller cam that I spec'd through Comp Cams. Engine has World Products Windsor Jr. heads that I've been really happy with. The question: I know I will be changing out valve springs, but can I sneak the roller lifters into their bores without pulling the heads?....Looks pretty tight on the end cylinders just eyeballing it. If I have to pull the heads, then I'll just pull the motor and call it a winter project. If not, I'll just remove the shock tower supports and work on engine in the vehicle. Opinions welcome! Thanks for help on this. GT1966
  • Sponsors(?)
mtaqua
345
why not just pull the intake to change the lifters? Also, what about the metal in the engine from the cam lobe? Might want to tear it down anyways.
rbohm
SN Certified Technician
Apr 12, 2002
6,619
531
204
61
tucson,az
as i recall, with stock heads swapping out the roller lifters is no problem with the heads in place.
PoppyMod
617
Severna Park, MD
Hi,
I've gone through those iterations in lifter changes. But, as was mention, if you wiped a lobe, then by all means tear it down, thoroughly clean and re-build. No question!
As far as the roller's go, you can either go the spyder route or link bars. They both will work, the "links" are more expensive of the two. But the bigger story here is, again, tear it down, otherwise, you'll have no O/P if any now.
BTW, I ran those heads, as well. They help me make 348 RWHP at one point.
Have a nice winter!
Realmongo
I prefer to be called "Evil Genius"
2,310
40
99
Western Mass
Yes, you are correct. Starting with the E5AE heads, the heads were cast to allow clearance to replace the roller lifters.
Thread starter Similar threads Forum Replies Date
mustangramair SOLD Tfs Stage 1 Cam, Tfs Valve Springs, Hydraulic Roller Lifters Engine and Power Adder 0
8 Ford Racing Hydraulic Roller Lifters Sbf Engine and Power Adder 0
9 Hydraulic Roller Lifter selection assistance 1994 - 1995 Specific Tech 5
D stock hydraulic roller lifter question Fox 5.0 Mustang Tech 6
hivewax Hydraulic Roller Lifter Kit Classic Mustang Specific Tech 23
allballsmustang hydraulic roller lifters 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
M hydraulic roller lifter ? Fox 5.0 Mustang Tech 3
faultlessfocus Solid Roller vs. Hydraulic Lifters? Classic Mustang Specific Tech 10
J Hydraulic roller lifter question 1994 - 1995 Specific Tech 5
Y Installation of hydraulic roller lifters? Fox 5.0 Mustang Tech 0
94tang WTB/Trade 302 hydraulic roller cam Engine and Power Adder Parts 0
Blucifer99 Engine Quick valve lash and preload question hydraulic roller Fox 5.0 Mustang Tech 0
K Engine Please Help Edelbrock 5023 E Street Heads with hydraulic roller cam Fox 5.0 Mustang Tech 6
J Cam Research SBF Hydraulic Roller Engine and Power Adder 0
S Solid Roller & Hydraulic Roller Cam Issues Fox 5.0 Mustang Tech 0
S Comp Cams hydraulic roller cam setup Engine and Power Adder 0
R FS: CI billet core hydraulic roller for 408+ 351W Engine and Power Adder 0
RyanSG Comp Cams XE274HR-12 Hydraulic Roller Cam, $120 Shipped or Trade For F-303 Cam Engine and Power Adder 1
1 do 351 hydraulic roller parts fit non hydraulic roller engines Fox 5.0 Mustang Tech 6
I mechanical roller? or just stick to hydraulic? Fox 5.0 Mustang Tech 14
wlink1 COMP CAMS XTREME ENERGY XE282 HYDRAULIC ROLLER 1994 - 1995 Specific Tech 6
W Solid versus Hydraulic Roller Camshaft? Fox 5.0 Mustang Tech 3
The Fox Hydraulic, Solid and Roller... Fox 5.0 Mustang Tech 2
7 hydraulic roller to solid roller? Fox 5.0 Mustang Tech 4
Busted07 FMS Hydraulic roller listers (are these the ones i need?) Fox 5.0 Mustang Tech 7
nonosstang Hydraulic Flat Tappet vs. Hydraulic Roller Classic Mustang Specific Tech 26
fiveoho anyone running the 236HR Comp Cams XFI Hydraulic Roller Cam? Fox 5.0 Mustang Tech 1
kfellers Do I have hydraulic or roller cam? Fox 5.0 Mustang Tech 2
streetstang67 Cam: hydraulic, solid, or roller? Classic Mustang Specific Tech 8
W Hydraulic or Solid Roller Camshaft? Classic Mustang Specific Tech 10
Eilermoon '03 Convertible top stuck SN95 4.6L Mustang Tech 16
D Headers with Trick Flow heads and T5 Hydraulic clutch? 1965 - 1973 Classic Mustangs -General/Talk- 3
droopie85gt SOLD Lunati Hydraulic Link bar Lifters, Engine and Power Adder 1
L Paint and Body How do I remove convertible top hydraulic cylinders on '92 LX Fox 5.0 Mustang Tech 0
6 hydraulic clucth 1965 - 1973 Classic Mustangs -General/Talk- 4
My92cashtrap Fox Hydraulic Clutch...Pros/Cons 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
don ruggles Replacing bad convertible top hydraulic cylinder. 2005 - 2009 Specific Tech 4
Enzio Engine Hydraulic lifter adjustment-problem solved 1974 - 1978 Mustang II Talk & Tech 2
B Is this normal for hydraulic lifters? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
robthechemist Any benefit to upgrading the top loader bell housing to a T5 bell when doing a T5 conversion? 1965 - 1973 Classic Mustangs -General/Talk- 2
Pops Fun Hydraulic Clutch Assist kit 1994 - 1995 Specific Tech 5
Grn92LX Drivetrain Anyone using a modern driveline hydraulic conversion? Fox 5.0 Mustang Tech 4
Olivethefet Damaged rack and pinion hydraulic transfer line 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
U 351c 2bbl cam/hydraulic lifters problem/ choice 1965 - 1973 Classic Mustangs -General/Talk- 10
TheNudeLion Sn95.0 convertible hydraulic leak 1994 - 1995 Specific Tech 5
Edbert Hydraulic Top Cylinders 1965 - 1973 Classic Mustangs -General/Talk- 3
M SOLD Hays 650 Clutch Billet Flywheel Hydraulic Throw Out Bearing Drivetrain Parts 1
J 1980 Ford Fairmont 302 Hydraulic Conversion Fox 5.0 Mustang Tech 18
A Paint and Body Convertible Hydraulic Cylinder And Lines Install 1994 - 1995 Specific Tech 0
C Hydraulic Clutch Kit 1996 - 2004 SN95 Mustang -General/Talk- 9
