Its true diff fluid smells ok to me,
the real reason im on today is im looking for some advice.
i have a 8.8 turbo coupe rear end with 3.55gears with disc brakes and im ok with that but before i put it in my car i want to replace the clutch plates and all the bearings, if i get the same bearings from ford or hunt down the same oem bearings can i get away with using the old shims from the carrier and pinion?
im not changing anything other then bearings
thanks
thanks
