95BlackTan50
- Oct 28, 2004
- 116
- 0
- 16
fiveoho said:the flywheel is new. it comes with a 50 ounce imbalance. no need to balance
That's true in theory. My vibration problem was caused by an unbalanced "new" flywheel out of the box. After I had it balanced my vibration was gone. The machine shop drilled out a significant amount of metal to make the flywheel balance. He also added a little metal to my pressure plate make it more balanced as well.
Have you tried putting your stock transmission mount back in? The only reason I bring it up is that I think you said that your vibration started after you put in the poly mount along with your machined flywheel, etc. Someone else posted that going back to stock fixed their vibration.
Good luck.
Barney
