during my explorer gt40 manifold swap i found this loose/broken connector. Located right next to my ect sensor. What do you think this is supposed to attach to? I'm thinking this could be the cause of my problems maybe?
I bought this 88 notchback back in november and have battling this issue since the beginning. It did have 3 stuck injectors and a stuck FPR which I already replaced and the car drives a lot better and feels like it has a lot more power but I still cant get past these issues.
I have already done the following:
-replaced all injectors with new style 19# injectors
-replaced FPR
-replaced IAC
-replaced and adjusted TPS
-replaced all top end gaskets with new fel pro pieces and installed explorer GT40 intake manifold
-replaced ECT sensor
-replaced ACT sensor
-new platinum spark plugs
-previous owner installed FRPP spark plug wires
-inspected cap and rotor - look fine
-replaced numerous old vacuum lines
-replaced fuel pump(had 91 5.0 fuel pump laying around) and in take fuel hoses
Not yet done:
-replace MAP sensor
-replace distributor
Still upon cold start up this morning it will fire right up, but the second you touch the gas it either cuts out and dies completely or backfires out of the intake. Once warm it will not stall when giving it gas but does occasionally backfire. When driving the car revs smooth and makes good power but almost can feel a slight miss through the power band. Also, it seems like at idle it doesnt idle quite as smooth as it should.
Motor does not smoke at all and was told the motor has about 70k miles on it.
Any ideas where to go next? One of my coworkers is going to look at it when he has time, but who knows when that will be since our shop has been really busy so personal projects often get put to the side forever. I really want to get this car on the road ASAP though.
-replaced FPR
-replaced IAC
Not yet done:
-replace MAP sensor
