Well, I got my Accufab TB Friday. So, I ported out the upper to match the 75mm opening on the TB. It definitely seems to have picked up some from the FMS 65mm that I had on before. We'll see when I go back to the track August 6th.
I also went the the junkyard and found the male side of the tps connector (the connector that is attached to the wiring harness) and I got rid of my rigged up wiring setup and made it look factory.
I have yet to install the cruise control cable. If anyone has taken there's out, do you have to remove the drivers side fender liner? I see the cable dives into the fender, but I don't see it under the dash, it looks like it goes into the fender. I'll take a peak at the Haynes manual, but it looks like the fox cruise cable will bolt right up.
I think next summer I will upgrade to some 4.10's with 31 spline axles, Bogart drag wheels with ET Drags (if I can afford them, otherwise pro stars). And then definitely upgrade the stock clutch to a Spec Stage II with an aluminum flywheel.
Jake
Jake
