Engine Intake upgrade
92VermHatch
wichita kansas
92 Hatch Gt
mods done to motor: bigger maf with injectors to match, k&N intake, BBK fuel regulator, and MSD ignition. close to stock, never opened.
I bought a tubular upper, lower intake, and the spacer off a buddy and want to know if I need heads to install it. Not sure if ports are the same on stock heads. I don't know what all I need for the swap. I know I wont see massive gains by any means but id like to put it on. Its my daily so Id be in a rush to install it, and I don't want to start then realize I'm missing something.
PS: I do plan on getting a set of aluminum heads with a cam later on, any suggestions on budget heads, cam, rockers?
  • Sponsors(?)
General karthief
Mod Dude
Aug 25, 2016
17,287
5,586
193
polk county florida
Pretty much a plug and play intake swap, some finessing with the vacuum lines is all.
lots of options for heads and cams, depending on your intentions and other stuff.
92VermHatch
wichita kansas
So the lower intake ports are the same size/shape on the stock heads? And my goal with the car is to make decent NA power before going to pro charged. I was thinking trick flow stage 1-2 cam with 1.7 roller rockers then a set of aluminum gt40 heads.
Thread starter Similar threads Forum Replies Date
S New Guy 2003 GT looking for intake manifold upgrade recommendations SN95 4.6L Mustang Tech 1
NickMadore Stock MAF with upgraded Throttle body? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 17
T Engine Intake Manifold Upgrade issues SN95 4.6L Mustang Tech 4
Hudson N Do I have the upgraded intake manifold? 1996 - 2004 SN95 Mustang -General/Talk- 4
acoddo How Much Hp/tq Will These Upgrades Get Me? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 23
1987lxhatch Hey Guys New Lx Upgrade Help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 21
spirockp Long Awaited Upgrade... (edelbrock Intake) 1965 - 1973 Classic Mustangs -General/Talk- 8
MR BACKHAND intake manifold upgrade help SN95 4.6L Mustang Tech 4
L Time For An Intake Upgrade, Which To Choose? Fox 5.0 Mustang Tech 8
tjsteeda Steeda Boss Mustang Cold Air Intake Upgrade Kit 2005 - 2014 S-197 Mustang -General/Talk- 0
Vinnietbird Did I upgrade or not? Intake question... Fox 5.0 Mustang Tech 9
M Upgrading to BOSS 302 intake manifold, should I beef up auto tranny? 2010 - 2014 Specific Tech 2
Jake8 Opinions on upgrading exhaust, radiator, fan and intake manifold Fox 5.0 Mustang Tech 5
txredgt Bullitt intake upgrade? SN95 4.6L Mustang Tech 8
G upgrade question tuner and intake 2005 - 2009 Specific Tech 4
N BBK Intake Noise after upgrade Fox 5.0 Mustang Tech 17
PI98stang F/S sohc 4.6 with many performance upgrades needs rebuild, PI heads and intake S.IND Engine and Power Adder Parts 0
jivepepper TFS intake, Accufab oval TB, and T-trim Upgrade 1996 - 2004 SN95 Mustang -General/Talk- 16
1 Upgraded heads and Intake. Now its popping Fox 5.0 Mustang Tech 1
S Cold Air Intake Upgrade SN95 V6 Mustang Tech 9
98blackstallion p-51 or bullit intake upgrade? SN95 4.6L Mustang Tech 10
J Intake upgrade on SD car Fox 5.0 Mustang Tech 7
Slow5.0 Upgrading intake to TFS Track Heat , polished/ported Cobra intake coming off 1994 - 1995 Specific Tech 5
X 96 Intake upgrades? (cobra, 99-04)? SN95 4.6L Mustang Tech 6
jpctln MAF Sensor/TB Sizes - Intake Upgrades Fox 5.0 Mustang Tech 8
mustard Throttle body, intake, MAF and exhaust added, do I need fuel system upgrade? 1994 - 1995 Specific Tech 8
Gearbanger 101 For all you SN-95 guys looking to upgrade your stock intake. 1994 - 1995 Specific Tech 8
gtrackd02 Intake upgrades???? SN95 4.6L Mustang Tech 8
W Mach1 2003 coolant leaking rear of engine SN95 4.6L Mustang Tech 0
gearhead77 Engine Valve cover/ intake studs and other stuff Fox 5.0 Mustang Tech 5
markinms Engine Explorer Intake Swap Performance Issues - Need Help! Fox 5.0 Mustang Tech 10
65ShelbyClone SOLD WTB Weiand Stealth 302 or Summit Stage 2 intake manifold Engine and Power Adder 0
R Engine setting valve lash on stud mounted roller rockers with intake already installed. 1994 - 1995 Specific Tech 4
5 Intake manifold/ general mod advice 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
T 4 brrl intake/carb combo for stock 1966 fastback 289 1965 - 1973 Classic Mustangs -General/Talk- 2
J Engine Trickflow Intake Street Burner Spacer Needed? Fox 5.0 Mustang Tech 13
T 2016 Mustang GT *Random Misfire's CEL* Charge Motion Valve "Flaps" in Intake Manifold 2015+ (S550) Mustang -General/Talk 5
R Engine Smoke test for possible leaking lower intake gasket Fox 5.0 Mustang Tech 0
91GTstroked Engine Changing lower intake gaskets Fox 5.0 Mustang Tech 15
K Best way to clean 4.6L DOHC upper and lower intake manifolds? 1996 - 2004 SN95 Mustang -General/Talk- 3
91GTstroked Engine Lower intake vacuum leak Fox 5.0 Mustang Tech 7
R Engine My on going lower intake dilemma w/pics Fox 5.0 Mustang Tech 14
92j3ieje8 How long to wait before removing intake manifold? 1996 - 2004 SN95 Mustang -General/Talk- 2
D F-150 4.2 Intake Manifold on V6 Mustang? SN95 V6 Mustang Tech 1
BETTERBULLITT Intake plastic nipple broke, antifreeze spewing everywhere. Now what? 1996 - 2004 SN95 Mustang -General/Talk- 5
Ultra90GT For Sale 351w GT40 tubular intake + extras Engine and Power Adder 0
P Looking to get a Intake plate 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
S 2000 3.8l lower intake 1996 - 2004 SN95 Mustang -General/Talk- 0
R Engine Upper intake & Components - Carbon buildup? Fox 5.0 Mustang Tech 4
02 281 GT LMR is making an ‘89-‘93 stock intake tube repro 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
