Engine Issues After Cleaning Engine Bay
David Pepiton
662
68
49
31
Laveen, Arizona
Well since I replaced a PS pump that was leaking all over over the drivers side of my car since I got it in December. well today I wanted to start cleaning it off so armed with a degreaser I go down to the local shelf serve car wash and go to town cleaning everything on the drivers side engine bay from firewall to the radiator (at about 11am). Understand I had and still have a ton of PS fluid all over the engine bay along with motor oil from the valve cover and rear main. well long story short I ended up spraying down the entire engine bay but focused mostly on the front and drivers side.
Now the drive home was fine so i think cool. get a call from the parts store that my sn95 master cylinder is in so ill go get it (time is 1:15pm). Jump in the stang and turn the key and a fairly hard start ok thats odd so I let it sit for a minuet and the idle is is ranging from 600-900 so I pop the hood and find a vacuum line had come off so I reconnect it and no change. I think hmm well lets just see how it does around the block so back out the drive way and put her in drive and give it about 10% throttle and it feels like its trying to die. well I make it around the block (very short drive) and its still falling on its face. so pop the hood again and try and see if it stumbles and I cant get it to do it by hand only while in drive and under load.
So here I sit needing assistance asap.
  • Sponsors(?)
David Pepiton
662
68
49
31
Laveen, Arizona
ok so im getting it to stumble while not under load but doesnt break up over 1k.
while under load it will break up all over the place.
I have a new cap and rotor, new o2s, new coil new plugs and wires. new fuel filter.
David Pepiton
662
68
49
31
Laveen, Arizona
yeah but its 110* out and sat for 2 hours i cant get 5 gallons of water to last that long in a bucket with the lid on hahahaha its been nearly 3.5 hours since i washed her now. man i wanted to go to dennys...
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
10,043
5,955
204
31
Hillsborough county
Dielectric grease..... get some pull your connections apart add grease put back together. This will help keep out moisture. I have a SVO cobra hood with a working scoop... so my dizzy gets wet, when it gets wet the car stumbles and pops and breaks up before the rpms come up.... Add grease no more problems when it rains.
Good Luck.:jester:
jcgafford
5 Year Member
Jan 7, 2012
1,114
94
94
43
Adrian, MI
www.stangnet.com
have done that with even "new" cars. can take days to dry out. i have ruined parts by trying to force dry it by running the engine. set it out in the hot sun with the hood up for a couple days, drive your dd in the mean time.
David Pepiton
662
68
49
31
Laveen, Arizona
well oddly enough I just bought a tube of DG. my fox doesnt have ac, doesnt have door panels or a working radio and id rather drive that then my navigator any day. actually im gunna sell it to fund a few projects for the stang and stuff around the house.
5point0stang88
205
15
29
Hmmm sometimes my car breaks up when it rains even a like rain. I don't have good scoop. First started when I went thru a flooding low area, I nearly didn't make it out lol. I misjudged, and knew I couldn't stop so I punched it. Kept trying to die on me, seemed like water mix with gas (I do have the filler tube leak)
But it's been months and I don't think it happens anymore
Sent front my SGS3 Epic 4GLTE Touch
David Pepiton
662
68
49
31
Laveen, Arizona
if you got water in the cylinders you would likely bend a rod or valve.
I made a custom CAI for a friends 06 Hyundai Sonata V6 with in a week it rained he drove through a huge puddle and water got sucked up into the engine and he bent 3 rods and bent 2 valves.
RangerJoe
I leave the horn on while driving
5 Year Member
Apr 26, 2010
2,666
1,232
174
Georgia
Take your distributor cap off and let it dry out. You probably got moisture inside of it.
Joe
cdurbin
5 Year Member
Jul 27, 2012
565
104
64
48
North Charleston, SC
Should I use a water hose, or a pressure washer? I have an electric pressure washer that is about 1500psi.
Or a car wash spray wand? Sorry for all the questions. This is my DD and I don't want to jack it up.
jrichker
StangNet's favorite TOOL
SN Certified Technician
Mar 10, 2000
27,357
2,824
234
74
Dublin GA
lowendmac.com
Don't use any more water pressure than you can get out of a garden hose.
Use some mineral spirits in a 1 or 1.5 gallon garden pressure sprayer to loosen up the heavy grease and oil deposits. You can get the garden pressure sprayer and the mineral spirits at any home improvement store or Ace hardware. Use some quality engine wash to do the engine compartment after the mineral spirits bath. Cover the electrical items with plastic or zip bags. Have some WD40 ready to spray the ignition wiring, inside of the distributor cap and distributor when you get done.
The first time you drive the car, all the leftover moisture will condense inside the distributor cap and cause rough running, and maybe a no start. Get out the WD40 and some paper towels and wipe down the ignition system and inside of the distributor cap again...
Thread starter Similar threads Forum Replies Date
The_Grayt_1 Considering buying a clean 06 GT and want toi know any common issues? 2005 - 2009 Specific Tech 7
Tally_4.6 Cleaned up my TB, idle issues? SN95 4.6L Mustang Tech 11
J Engine 93 5.0 issues with iddle and no power. Fox 5.0 Mustang Tech 2
Mystang66 Solenoid issue? 1974 - 1978 Mustang II Talk & Tech 7
F Electrical Tracking down my always full fuel gauge issue....89 Notch 2.3L (N/A & Turbo) Tech 3
sigsterrr Electrical Charging issue Fox 5.0 Mustang Tech 8
T Parasitic drain - SJB issue 2005 - 2014 S-197 Mustang -General/Talk- 5
R Engine stud mount roller rocker poly lock nut issue. Fox 5.0 Mustang Tech 2
M 2003 GT auto shifting SN95 4.6L Mustang Tech 0
A New fox owner, idle issues need some advice Fox 5.0 Mustang Tech 14
D please help fuel pressure issue 1996 - 2004 SN95 Mustang -General/Talk- 0
J Engine RPMs dropping issue 2010 - 2014 Specific Tech 0
D Electrical issues 2007 GT 2005 - 2009 Specific Tech 1
J 2000 GT Idle/Running Issues SN95 4.6L Mustang Tech 6
calmlikeabomb 96 Cobra power steering issue... what is this line? can I replace it? SVT Tech Forum 0
B Fuel Fuel pressure Issues / AFR Fox 5.0 Mustang Tech 0
R 89' Stang - MS2PNP - Post tune - Surging issues Digital Self-tuning Forum 5
isaiahfig71 brake issue 1996 - 2004 SN95 Mustang -General/Talk- 1
isaiahfig71 Brake light issue SN95 4.6L Mustang Tech 0
J Hand brake issue Fox 5.0 Mustang Tech 4
G 1988 4cyl 5 speed (Compression issues) [Help!] 2.3L (N/A & Turbo) Tech 23
R Interior paint issue 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
Foxbody1995 Turn signals issues 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
A Overheating issue 2005 - 2009 Specific Tech 6
S Electrical Ignition Issues No Power to NSS Fox 5.0 Mustang Tech 1
T Fuel pump code issues 1994 - 1995 Specific Tech 5
T Aod transmission issues Fox 5.0 Mustang Tech 1
W 1967 dynacorn frame rail and shock tower assembly issue 1965 - 1973 Classic Mustangs -General/Talk- 0
W Fuel tank- gauge issues 1996 - 2004 SN95 Mustang -General/Talk- 2
D 97 GT Wiring issues SN95 4.6L Mustang Tech 1
N Cant find answer to window issue Fox 5.0 Mustang Tech 5
C Unique Fuel Pump Issue Fox 5.0 Mustang Tech 31
B Slight surging idle issues Digital Self-tuning Forum 14
L ambient light issues 2010 - 2014 Specific Tech 0
1990slow50H Starting issue, electrical problem? Fox 5.0 Mustang Tech 5
N Fuel issue 2000 v6 SN95 V6 Mustang Tech 2
Foxslider Electrical issue... no power. Fox 5.0 Mustang Tech 11
S Megasquirt PNP2 460SBF startup/idle issues Digital Self-tuning Forum 9
65-Fstbk 302HO With Quickfuel Slayer 600 Starting Issues Digital Self-tuning Forum 0
5 NEED ADVICE FROM COMMUNITY MEMBERS 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
nathanruschill 2000 Mustang Gt auto starting issue!! SN95 4.6L Mustang Tech 3
F Electrical 2003 Mustang GT - Brake and Blink Fuses Blow SN95 4.6L Mustang Tech 6
K 94 Mustang GT EGR ISSUES 1994 - 1995 Specific Tech 3
M Paint and Body '69 Coupe Door Latch/Strike Issues 1965 - 1973 Classic Mustangs -General/Talk- 5
B Fuel pressure issue 95 mustang 5l 1994 - 1995 Specific Tech 8
trlps_ Oil Pressure Issue 1996 - 2004 SN95 Mustang -General/Talk- 5
8 Engine Turbo fox build hot start issue Fox 5.0 Mustang Tech 7
1989LXFOX Engine Starting Issue Fox 5.0 Mustang Tech 4
R 1966 Mustang Brake Issues 1965 - 1973 Classic Mustangs -General/Talk- 9
TexasFireman Forced Induction Crank Trigger Clearance Issues Vortech Fox 5.0 Mustang Tech 4
