I've been slowly working on some of the unfinished projects in the kitchen again. I crawled into the attic and finished wiring the outlets for the under cabinet lighting and finally reinstalled the dishwasher. It appears that the seals in the water valve have dried up, so now I'll have to deal with that, but it's in place for now.
I also got a high efficiency front load washer from Facebook Marketplace last week for $80. The guy said it wasn't draining but everything else appeared to work. I thought that that's no big deal, my old washer did the same thing. It was usually the filter that was clogged with lint or dog hair or whatever else went through the cycle. I figured it was either that or the drain pump died, and the pump costs $20 - no problem!
So I got it home and started investigating. Pulled the filter and it had a penny and a bunch of what appeared to be coarse sand in it. I thought that that's most likely the problem, he had younger kids and they had a bunch of sand in their pockets that went through the wash and destroyed the pump. So I ordered a pump, take the pump and housing out of the machine, clean the housing, remove a large piece of what looks like plastic from the pump section of the housing, then check the pump and find out there's nothing wrong with it. So I go ahead and put it back together. I get it all hooked up, try to run a cycle and find out that the drum won't agitate. So I open it up again, try to manually move the drum and find out it's hitting something and locking it up. Back to Google I go for more research! Come to find out that the spindle and arms that hold the drum in place are made of cast aluminum. Laundry soap enters the tub that contains the drum and slowly eats away at the cast aluminum causing the arms on the spindle to fail.
SO.....I ordered a new spindle. Now I'm into this washer for about $200 - as long as that's the only problem with it! If it is, it's at least $400 saved. If not...... well, let's just not go there!! Lol
