I've searched and found little to no results so now i post here in hopes that someone can help.
Ok, so on my 92 convertible, the top plate of the trans has a sensor on it, specifically on the back left if you stand behind the transmission. If you unscrew the sensor, there is a prong inside. I'm pretty sure this prong has something to do with the nuetral safety switch, but i'm not certain. I do know its not the backup light switch since that clearly is on the side of the transmission.
The t5 i just bought does not have the sensor or even a spot for the sensor and my 93 4 cyl t5 doesn't either. I was a little scared thinking i just bought a 4 cyl t5 but i checked the size of the input shaft and the freeze plug thing in the front by the input bearing retainer (said timken).
So why isn't there the sensor on the top of the transmission?
Also, since i'm on the topic of transmissions, i would like some input. There isn't much in and out play (if any) on the input shaft but there is quite a bit of side to side play. Also you can spin the input shaft pretty easily. You can basically spin the input shaft and let go and it will keep spinning a couple times. On my 92 verts trans there was a decent amount of drag, where as this one there is not.
Can someone let me know what they think. I'm positive that i could rebuild a t5 transmission even though i've never tried. It doesn't hurt that i have a manual as well . The only thing is, its very general on things to look for. It basically tells you how to take it apart and put it back together.
Thanks in advance
EDIT: i just looked at the 4 cyl t5 that is in the car now. I checked the size of the input shaft by placing the 85 ranger pilot bearing over the shaft. It fit perfect and i walked over to the t5 i just bought and it didn't fit. So i know the input shafts are different. I looked close and the 4 cyl t5 had the same damn TIMKEN plate. Well i could only see KEN and the whole part number which looked to be LMG7010-BCE. The door jamb code reads 2GFGG under the TR section.
So i'm really confused here.
Thanks in advance
