just did explorer intake swap...help!
smkshw
5 Year Member
Feb 12, 2010
1,095
235
94
i just did the swap,did some reading,seemed easy enough,drilled and tapped the act sencor was going well until i noticed that my lower intake didnt have the hole for the egr coolant return line!...its all together torqed and ready to go,anyone know if there is another way to plum the line so i dont have to take it apart again?
  • Sponsors(?)
Vinnietbird
584
Plug off the egr coolant lines.I had mine welded shut on the water tubes,repainted them black,installed them,done.No more tubes (small hoses) to the throttlebody spacer.Mine has been that way for 5 years with zero issues.
stykthyn
5,302
2,733
223
gainesville
I ghetto capped mine off. No super hot EGR spacer woot woot.
Bullitt347
man bewbs please...
Mar 23, 2007
2,199
1,006
184
Pacific NW
The cooler hoses to the EGR spacer will actually make the EGR plate COOLER! By blocking off the hoses the EGR plate actually runs HOTTER! Now if the EGR is disconnected (I.E. the EGR passages are blocked off in the intalke or heads) then there is no need for the cooler lines/hoses.
smkshw
5 Year Member
Feb 12, 2010
1,095
235
94
my egr is still hooked up,so i think i need the coolent flow?,i was thinking of splicing the heater coar line with a tee and run it there,that should be fine?
Bullitt347
man bewbs please...
Mar 23, 2007
2,199
1,006
184
Pacific NW
Most stock 5.0's have a nipple coming off of the coolant pipe that runs from the heater hose to the front of the intake manifold. So splicing or placing a T off of one of the heater hoses should work the same, just at a different location that what is "stock".
Mustang5L5
i'm familiar with penetration
Mod Dude
Feb 18, 2001
33,055
9,203
224
Massachusetts
Unfortunately, you'll have to pull the lower intake off and tap a 3/8" NPT port in either one of the two rear bosses for the nipple on the stock 5.0 intake.
You can just cap the lines off although if your EGR is functional, i wouldn't. Personally, i'd just pull the lower and do it right
Mustang5L5
Mod Dude
Feb 18, 2001
33,055
9,203
224
Massachusetts
He would have to tap into the downstream hose in that case. If he taps into the upstream hose, the pressure at the inlet and outlet will be the same and the coolant in the EGR won't move at all.
If he taps into the downstream hose (of the heater core) then there should be enough pressure differential of the coolant across the fins to force coolant to flow through the EGR spacer.
By downstream of the heater core...i mean after the coolant flows into the core and comes out. So whatever hose the pipe with the nipple is hooked too....use the other one.
Ideally, i'd rather put it in the correct spot in case the flow through the heater core is very good...and in that case coolant won't really flow that well through the EGR
smkshw
5 Year Member
Feb 12, 2010
1,095
235
94
i would rather do it right also but its all together now,i realy dont want to take it all apart again....im going to try to splice into the down stream of the core,i think it should be ok....will find out tomoro...thanks for help..
tmoss
Gettin Wired
7,132
20
118
Saint Louis, MO
Visit site
I have an Explorer heater core hard line hanging on the wall from an intake core purchase that has both the supply and return nipples on the two lines - you'd just have to swap that out. Look in a local JY for one like it.
tmoss
Gettin Wired
7,132
20
118
Saint Louis, MO
Visit site
See my post above. Even if the heater core was plugged, the pump pressure in the supply line would push water through the spacer and into the hard return line - the differential pressure is there to force flow.
Thread starter Similar threads Forum Replies Date
mikestang63 Engine Did The Explorer Intake And Headers Install Fox 5.0 Mustang Tech 7
enyawix Did The 5.0 Explorer And Early 4.6 Use The Same Engine Management System? SN95 4.6L Mustang Tech 2
V Those with explorer motors/gt40/p heads, what did you dyno and what mods?? Fox 5.0 Mustang Tech 5
Woody3882 Did you start the restoration in Arkansas of a 1965 Mustang coupe and sold it in May of 2014 Regional Forums and Event Information 0
DarkFox Electrical I've searched for wiring diagrams but did not find what I was looking for. Fox 5.0 Mustang Tech 4
N What did I do 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 30
GodStang Did I do this right? Video Datalogging Digital Self-tuning Forum 4
Habu135 Just Did the Unthinkable 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 65
J I DID IT- upgrade. SN95 4.6L Mustang Tech 0
R Engine Did I install my cylinder heads wrong Fox 5.0 Mustang Tech 3
LILCBRA So I did a thing today...... 1974 - 1978 Mustang II Talk & Tech 14
MrPerfect2 Fox Why did FORD use such lower sized gears in rear IMO 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 29
D 1998 Mach 460, what I found out, and what I did... Mustang Sound & Shine All 2
8 Little project I did 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 26
KZGUNS Paint and Body Did a thing this weekend 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
R 66 Front disc brake conversion, Did a search and couldn't find an answer 1965 - 1973 Classic Mustangs -General/Talk- 4
STROKED_LX Fuel 89 Notch, cranks no start (did check list) Fox 5.0 Mustang Tech 4
J Non Mustang question.. Which 1994 - 1997 F-150 Truck did the 351 W Come in? like which trim? 1996 - 2004 SN95 Mustang -General/Talk- 3
D Did a little dressing up on the 5.0 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
M Electrical 92 GT 306 Vortech - Did I fry my ECU??? Fox 5.0 Mustang Tech 17
M What Did This Toploader Come Out Of 1965 - 1973 Classic Mustangs -General/Talk- 3
Keith5.0GT Where Did You Mount Water Temp Gauge Fox 5.0 Mustang Tech 26
gruvee87vertgt Fox Did Search, No Luck. What Yokes For Aluminum Driveshaft W/aod Trans? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
horse sence Did The 2007 Gt Come With A 5 Speed Automatic? 2005 - 2014 S-197 Mustang -General/Talk- 6
Real time recon What Did A 65 Cost New In 65 1965 - 1973 Classic Mustangs -General/Talk- 1
Mustang5L5 When Did '93 Cobra Intakes Get This Expensive? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 121
LaserSVT So I Did A Fing To The Vette Mustang Sound & Shine All 0
W Heads, Gasket, Block, What Did I Blow Up? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
F Maximum Motorsports Customer Service - Did I Call On An Off Day?/please Help. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
Gear grabber Did I Really Get A Flat ? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
wgreenlee4 Did Anyone Forget These Existed? Foxbody Dark Era 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
MrFoxNutCase So I Did This Long Arsed Post About Smog And Efi Stuff 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
gruvee87vertgt Did Search - No Luck Size Belt For Ac Eliminator & Underdrive Pulleys? Fox 5.0 Mustang Tech 2
Smokegreymonster99 Heater Hose Nightmare. Did It Cost Me My Engine!!! 2005 - 2014 S-197 Mustang -General/Talk- 0
Rjaaaaaa Ouch !!! Boy Did It Hurt 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 44
R Hello! Where Did This Cobra Ornament Come From? 1965 - 1973 Classic Mustangs -General/Talk- 3
8 What Year Did Ford Start Using A Better Sterio? 1996 - 2004 SN95 Mustang -General/Talk- 7
L Electrical Did Tune Up, Had Horrible Idle, Fixed Idle Issue...now My Battery Light Is Coming On.... 1994 - 1995 Specific Tech 18
L Engine Did Tune Up, Idles Like Crap After... 1994 - 1995 Specific Tech 2
MrFoxNutCase Ooops I Did It Again (2 Notches Better Than 1?) 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
02 281 GT Welding: How Did You Learn? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 54
larrym1961 Who Has Dumped A Mail Order Tune For A Moates Quarterhorse Tune, What Did You Think? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
O What Did You Do To Your Sn95 Today? 1996 - 2004 SN95 Mustang -General/Talk- 33
Jason 302 Did 5 Lug/4 Disc Swap, Brakes Are Weak Fox 5.0 Mustang Tech 35
Mattstang04 Did My First Mods Today. 2015+ (S550) Mustang -General/Talk 4
M What The %#@&$ Did They Do To My Car? 1996 - 2004 SN95 Mustang -General/Talk- 2
90lxwhite This Months Mm&ff Did An Article On A 94 Vert Indy Pace Car. Do These Hp #'s Sound Low? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
CarMichael Angelo What I Did For Thanksgiving. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
mikestang63 Did A Quick Walk Around Video After Cleaning Her Up A Little 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 30
k1DBLITZ Did You Know That.... 2005 - 2014 S-197 Mustang -General/Talk- 1
