sup guys, so to make the story short I bought a 03 gt. Turns out it needed a motor. So I bought a motor out of a 2004 crown Vic with 32k miles. Well, turns out it's a npi motor and instead of selling it I decided to just make it work. So this is what I have.
03 gt,npi block,pi heads, pi intake, stage 2 cams,75 mm throttle body, throttle body spacer, cold air intake and cat less h pipe. Stock tuning.
Car cranked up fine was misfiring, had two bad coil packs replaced and she was chopping smooth. Car was driving fine, has a slight miss in the higher rpms but won't set a mis fire code. A couple weeks go by and I get a passenger lean bank code along with gas cap evap code.
I have spent lots of time checking vacuum leaks with starting fluid and brake cleaner. I can't find anything. Are these codes from running on stock tuning?
I live in middle ga and can't find anyone who will tune my car for less then 1g. To me it's not worth paying this as I still wanna go forced induction. Any reccomendations?
Also the radiator fan motor has died causing the car to run hot. What are some good aftermarket radiator fans? I will go back stock if its better but I like upgrading when I can, if it's reasonable.
I'm Just trying to get this thing running right!
