Lincoln Mark Viii Fan Control Module
  • Sponsors(?)
Mustang5L5
i'm familiar with penetration
Mod Dude
Feb 18, 2001
33,131
9,350
224
Massachusetts
Possible? maybe.
Does anyone know how? Prob not. For the cost of that module, and the time and effort needed to research the wiring and programming of the module, it's prob cheaper and easier to purchase an aftermarket fan controller and 75A relay
jAEded
418
26
39
Cali
I guess maybe I have to find a intact wire harness from the module to fan and any where else to see what they're doing. I'm guessing they're tying in to the ect or a feedback signal from the pcm? If true then I need to tee in a ect sensor from a mark viii if it isn't the same one as the mustang? The rest would be stand alone I think.
I was hoping maybe someone has already done it or had experience with it?
mikestang63
SN Certified Technician
Aug 27, 2012
9,911
6,693
204
In the garage
IMO, I would spend the extra few dollars and get a tried and true VSC that is new with a warranty and a thousand writeups on how to install. My first choice is the FAL 33054 and then the DCC SP2. Better to spend an extra $50 and know it works than skimping and the car overheat.
jAEded
418
26
39
Cali
I don't mind spending money if its value added. I don't want to go $500 on a set of valve covers or things like that.
My reason for wanting the mark viii stuff was cause its all from Ford and if I need another part its easy to find and quick to change out, plus the Ford stuff seems pretty durable comparatively. It will ease my mind when I'm 60 miles away from anything resembling help. :)
I did find on Lincoln forums that it looks all stand alone except the temperate signal is a data link from the Lincoln PCM. The module ties in to the high side ac pressure so if it goes above a certain pressure the fan stays on regardless of engine temp or whether the ac is in use. Thought was kind of cool. Is data link a v or ma signal?
jAEded
418
26
39
Cali
I found these on another forum. I need to find out what signal is on the data + \ - pins.
Mustang5L5
Mod Dude
Feb 18, 2001
33,131
9,350
224
Massachusetts
The mark 8 fan speed is variable. In fact, the name of the controller (VLCM) means Variable Load Control Module.
I've found this for what it actually controls
The variable load control module (VLCM) controls:
the cooling fan motor operation and speed.
the A/C clutch operation.
other non-A/C functions.
It also increases and decreases the cooling fan motor speed as necessary, depending on the refrigerant system high-side pressure.
Turns the A/C clutch circuit OFF if the high-side pressure exceeds 2930 kPa (425 psi).
It also gets inputs from the PCM. The more i search, the more i doubt it could be configured as a standalone variable controller.
jAEded
418
26
39
Cali
From the C106 connector picture. Would pin # 23 data -, be the equivalent of pin 17 (pink\lt green) of a 91 - 93 eec-iv? Would pin # 21 data + be the equivalent of pin # 48 (white\pink)?
I imagine the lincoln ect sensor voltage tables will be a little diff than for the mustang.
jAEded
418
26
39
Cali
It looks like I have pins 17, 22 and 48 on the 93 eec-iv. I'm not sure which ones to use.
Thread starter Similar threads Forum Replies Date
Blown88GT SOLD Lincoln Mark VIII Fan with Overflow Engine and Power Adder 4
stangbro916 Mark Viii 4v swap to 98gt has caused overheating and I'm stuck plz help!!! 1996 - 2004 SN95 Mustang -General/Talk- 11
stangboy Who's Using A Lincoln Mark Viii Fan? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 51
D 97 Mark Viii Lincoln Heads Same As 97 Cobra? SVT Tech Forum 0
LaserSVT 1998 Supercharged Lincoln Mark VIII LSC Other Classifieds 0
G For Sale: Lincoln Mark VIII Electric Fan Engine and Power Adder 1
95Vert383AOD Say Hello to my lil Friend!!! 5.4 Lincoln Mark VIII!!! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
95Vert383AOD 5.4 4V Navi Lincoln Mark VIII SWAP Other Auto Tech 3
cedp83 Lincoln Mark VIII parts SN95 4.6L Mustang Tech 1
P 80mm Lincoln Mark VIII MAF w/4" adapter & OBD2 pigtail $45 shipped Engine and Power Adder Parts 0
Obsol3te 93 Lincoln Mark VIII Drivetrain Other Classifieds 0
brent_cosenza lincoln mark VIII swap to 2002 GT??? SN95 4.6L Mustang Tech 14
Redfire 05 Lincoln Mark VIII Fan Install Problems Fox 5.0 Mustang Tech 18
Turbo92PGT Lincoln Mark VIII SN95 4.6L Mustang Tech 2
ga289stocker 1993-1999 Lincoln Mark VIII 4.6 Dohc ???'s SN95 4.6L Mustang Tech 4
aod92 LINCOLN MARK VIII FAN QUESTION Fox 5.0 Mustang Tech 8
lxwants12's PLUG FOR ELECTRIC FAN LINCOLN MARK VIII Fox 5.0 Mustang Tech 2
lxwants12's ELECTRIC FAN 93 - 96 LINCOLN MARK VIII Fox 5.0 Mustang Tech 7
GearHd6 Lincoln Mark VIII Fan Question Fox 5.0 Mustang Tech 8
GreGTen Lincoln Mark VIII MAF 1994 - 1995 Specific Tech 2
Blown94coupeGT Lincoln Mark VIII 4.64v swap??? SN95 4.6L Mustang Tech 8
Ford69 My Lincoln Mark VIII Drawing ! Fox 5.0 Mustang Tech 8
HybridFuel Lincoln mark VIII engine in a cobra??? SVT Tech Forum 1
BDAWK2002 Lincoln Mark VIII 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
camarokiller5.0 Lincoln Mark VIII Electric Fan took a crap Fox 5.0 Mustang Tech 2
G 93 Lincoln Mark VIII mass air sensor Fox 5.0 Mustang Tech 1
J whats the difference, Lincoln mark VIII VS. Cobra ??? SN95 4.6L Mustang Tech 4
The Black Pearl Lincoln Mark VIII motor for sale SN95 4.6L Mustang Tech 1
Slow5.0 Anybody know good website/forum for Lincoln Mark VII and VIII Fox 5.0 Mustang Tech 3
Slow5.0 Anybody know good website/forum for Lincoln Mark VII and VIII SN95 4.6L Mustang Tech 3
Slow5.0 Anybody know good website/forum for Lincoln Mark VII and VIII SVT Tech Forum 0
stangboy What size injectors did the DOHC Lincoln Mark VIII's come with? SN95 4.6L Mustang Tech 1
C Converting a 1980 Lincoln Mark VI from a 302 to a 351? Other Auto Tech 5
silverlx50 Wheels-Tires How do I know what wheels I can run with Lincoln Mark VII front rotors? Fox 5.0 Mustang Tech 2
J Electrical Alternator (91 Mustang GT & 89 Lincoln Mark VII) Fox 5.0 Mustang Tech 169
Mustang5L5 Lincoln Mark 7 time capsule 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 32
S Mark 8 Cobra Build 1996 - 2004 SN95 Mustang -General/Talk- 5
LS1Nova Wilwood Brake Options - 1977 Mark V Lincoln Other Auto Tech 8
E Lincoln Mark VII Rear end in a 98 GT? SN95 4.6L Mustang Tech 4
B Lincoln Mark VII 8.8" in a Foxbody? Fox 5.0 Mustang Tech 21
8 89 lincoln mark 7 5 speed with mods best offer Other Classifieds 0
E Will Lincoln Mark VII Marchal fog lights fit and 86 mustang gt? Fox 5.0 Mustang Tech 1
5.0TailPipeHump Lincoln Mark VII Lsc ecu 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
mustanggt04fast 1993 Lincoln Mark 8 Motor 1996 - 2004 SN95 Mustang -General/Talk- 1
M lincoln mark 8 swap SN95 4.6L Mustang Tech 10
ID89GT 88 Lincoln Mark 7 Fox 5.0 Mustang Tech 14
PNW LSC 1990 Lincoln Mark VII LSC SE - Lots of mods Other Classifieds 0
warriorpluto lincoln mark VII oil pan Fox 5.0 Mustang Tech 0
warriorpluto lincoln mark VII Fox 5.0 Mustang Tech 2
95Vert383AOD Lincoln Mark 8 suspension swap and fun this weekend 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
