To be honest, I'd revisit the cam. I've read a lot about the TFS1 cam being soft down low, while gaining top end steam. Not sure if swapping the intake out would give you more low end grunt than a custom grind cam suited for your AOD setup.
I have a Holley Systemax 2 on my car, because my heads demand that much flow. I'm going to put another recommendation in for Tmoss. Incredible value and customer service. It will amplify the torque on those 170cc heads better than an aftermarket intake. A bigger intake will kill the air velocity down low, and the heads will suffocate before the intake and you will lose all the top end too. If you look at the multiple dyno tests on the different intakes, it takes a lot of head and cam before the Cobra style (Explorer Intake) starts to run out of steam.
Kurt
Man, I left this board for just a couple years and you guys are back to talking about "velocity down low"? Were my efforts all in vain?
I have not been around that long, can I have a refresher on that? Just curious if my thinking is correctMan, I left this board for just a couple years and you guys are back to talking about "velocity down low"? Were my efforts all in vain?
I am all in favor of a bigger intake, but you can't argue with dyno results.
Kurt
I still think the OP should revisit the camshaft.
Even I'm reconsidering my decision to run a TFS1 cam. I'll see how much $$ I've got kicking around when the time comes
But my combo will be similar. Tfs170s, tmoss ported Cobra, 75mm tb and a TFS1 cam
The brown truck dropped this off today- polished, ported and painted. Intake side opened to 75MM.
If anyone is into the bling bling I would highly recommend this guy.
Mike- yes he can polish just about anything.. hit him up at Ortiz Polishing on FB, His name is Fransisco Ortiz.
Kurt- I have polished many parts over the years and i can telll you he has at least 10-15 hours of time in this The thing is flawless..
It just has it's limitations like everything else and those limitations don't always agree with the way I drive the car. The rare chance I do get a WOT pull from 2nd all the way through 3rd, well, no complaints from me about the TFS1 cam then.
