Microsquirt and inputs
Tufgriz
11
Washington
I was curious if the microsquirt could handle inputs such as oil pressure, and if so would I configure the box to recognize the input? Thanks
  • Sponsors(?)
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
10,132
6,026
204
31
Hillsborough county
Yes it can, are you looking for the hardware side or the software?
you can use the adc6 and adc7 inputs to do this.. they are commonly called the baro and knock inputs and have all the required ADC conditioning done already. Once you have it wired into the unit you can simply do a custom field input to scale the sensor.
Tufgriz
11
Washington
I believe I have the hardware side taken care (factory gauge sensor and aftermarket electric sensor). Was looking more at weather the microsquirt could accept the input and where it would go and how I would configure it in tunerstudio to read the sensor. Still need to look up the sensor values for my sensors. So you are saying I have 2 available inputs? if so I may do the oil pressure and buy a fuel pressure sensor as well. Thanks for the reply
Thread starter Similar threads Forum Replies Date
S Another Idle surge post with microsquirt Digital Self-tuning Forum 5
J Microsquirt vs ms3gold box? Digital Self-tuning Forum 2
C Microsquirt tuning and surging idle problems Digital Self-tuning Forum 7
A Microsquirt setup and first start questions Digital Self-tuning Forum 9
U My microsquirt project Digital Self-tuning Forum 4
matt_ru Microsquirt with MSD 6A help Digital Self-tuning Forum 24
beyondEOD SN95 94-95 Microsquirt Pinouts Digital Self-tuning Forum 8
79pace Moates / TwEECer / MicroSquirt? Which one should I look into? Digital Self-tuning Forum 16
beyondEOD Fuel Pressure Sensor with Megasquirt Digital Self-tuning Forum 15
Jtoepper93 Turbo fox microsquirt help Digital Self-tuning Forum 16
beyondEOD 94-95 Mustang 5.0 AODE MS3 Gold Box w/ Microsquirt Digital Self-tuning Forum 62
beyondEOD 94-95 Mustang GT Auto Dual Microsquirt ECUs Digital Self-tuning Forum 14
S Microsquirt issue. Car won't start with SPOUT in Digital Self-tuning Forum 8
G Electrical Microsquirt harness help Fox 5.0 Mustang Tech 9
J My first microsquirt project Digital Self-tuning Forum 13
Nightstang00 Digital Tuning Coolant Temperature Sensor Microsquirt Fox 5.0 Mustang Tech 13
6 Help Need for a 4 cylinder swap with a microsquirt!!!!! Digital Self-tuning Forum 5
A Any help with Microsquirt tuning would be very much appreciated Digital Self-tuning Forum 14
94tang Fried Microsquirt? Digital Self-tuning Forum 7
maisonmays22 Microsquirt no start condition Digital Self-tuning Forum 31
maisonmays22 Microsquirt General Questions Digital Self-tuning Forum 1
E Stock 94 GT Microsquirt wont run/idle Digital Self-tuning Forum 2
OldManRiver Microsquirt V3-No start with spout in Digital Self-tuning Forum 15
Nightstang00 Idle issues with a foxbody and microsquirt Digital Self-tuning Forum 31
a91what Service Provided Megasquirt ECU support and Tuning Services - Tuning, Welding, Mechanic, Body Work... 5
A Ignition box with microsquirt Digital Self-tuning Forum 3
9 Microsquirt with strange cold start problem Digital Self-tuning Forum 5
Gunny87 Microsquirt not syncing up with tunerstudio Digital Self-tuning Forum 11
8 5.0 microsquirt mustang hits wall around 5000 RPM Digital Self-tuning Forum 25
Creomod SOLD Microsquirt for sale new mustang 86-93 Other Classifieds 3
U 5.0 Microsquirt start up help Digital Self-tuning Forum 11
8 5.0 microsquirt help Digital Self-tuning Forum 18
Blucifer99 92lx. Whats the difference between microsquirt and megasquirt for fox mustangs Digital Self-tuning Forum 10
1 97 explorer 302 microsquirt Digital Self-tuning Forum 41
danielhv danielhv 87 microsquirt project Digital Self-tuning Forum 76
H 1989 gt vortech supercharged microsquirt, having trouble getting idle set, need a tune to compare. Digital Self-tuning Forum 4
a91what Megasquirt/tuner Studio Tech Thread Digital Self-tuning Forum 16
darryl paarman A/C idle up control- Low input or High. ? Digital Self-tuning Forum 2
D Building a 302 and Require Input 1965 - 1973 Classic Mustangs -General/Talk- 8
K 1998 v6 mustang grease for input shaft SN95 V6 Mustang Tech 0
W Drivetrain T5 Input Shaft - Will it leak ? Fox 5.0 Mustang Tech 0
S T-5 input shaft for a Mustang 2 Bell housing 1974 - 1978 Mustang II Talk & Tech 7
J T45 input shaft 1996 - 2004 SN95 Mustang -General/Talk- 0
C Any links that detail computer codes (inputs/outputs resulting in check engine lights) - 1997 Cobra SVT Tech Forum 5
C Drivetrain Just need some input 2010 - 2014 Specific Tech 1
K Ignition coil input voltage. 1965 - 1973 Classic Mustangs -General/Talk- 1
W venturing into the Ford community. (in a way) new to Mustangs. Love the Foxs. would like some input on front suspension. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
JCBeaver Diagram for 12V Input wires going to the factory gauge cluster connectors? Fox 5.0 Mustang Tech 6
G Tuning input 92 5.8 with a mircosquirt Digital Self-tuning Forum 10
MTV593 Power train input 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
