Installed it all yesterday went to Best Buy and got a serial port to USB adapter got the MS version (the $59.95 version) TunerStudio plugged all the cables in, pulled up TS on the laptop, clicked on create new project, clicked on firmware-detect, cycled the key to on, fuel pump primes, does it's search, and then says no controller found! moved the cable to all 3 USB ports on my laptop and the same thing is happening!!! double and triple check all connections but no luck!!! the MS is working, the car will start but won't idle and I'm sure that's because all the basic settings need to be calibrated via TS! NEED HELP PLEASE!
The car is bone stock 87 GT AOD, I did convert it to Mass Air a year ago and Explorer 19 lb injectors but other than that stock and has been running great, I wanted to change to the MS before I install the new engine I have ready to go in and get familiar with tuning so when I make the switch I'll hopefully know what I'm doing, the new engine is a 306 with GT40 heads, intake with 70 mm throttle body, and E cam, and will be using 24 lb injectors, and in the near future adding supercharger so as you can see the MS and TS will be playing a big roll in the cars future so really need this to work!!
Help!
Help!
