Long time owner here with 170K original miles. I haven't experience any major problems. Only had one plug blowout due to not using a torque wrench on it. Had to replace the rear axle bearings. Minor ones are my driver side window motor is acting up. Not sure if it's the motor or switch. Also, the seatbelt has long been a nag as it doesn't retract fully. I'm sure there's a fix out there, just haven't done it. Steering rack has a creak/knock in it but doesn't affect any performance. You must use 75W-140 weight in the rear...the 90 lets it get too hot back there. Rear window defrost grid is failing on several lines. Heat/sunshine will make the headliner material fail at the rear and on sun visors if left down all the time. Last 2 summers have had to add refrigerant to the A/C. Rear pinion seal is leaking. Captain Obvious moment here...Usual wear and tear parts I've replaced are coils, plugs, shocks, belt, hoses, thermostat, filters, brake pads and rotors. Cleaned the IAC valve, mass air sensor, throttle body. Overall a very reliable vehicle.
