this is a thread i did on it awhile back. if you want, check out post #6, where i outline what i did to make it work.
http://forums.stangnet.com/showthread.php?t=349796
only other things i can think of:
i didnt mention it, but for me, removal of the mechanical fan and shroud was necessary to jack the motor enough. takes 3 minutes.
leave the bolts loose on each side until you get them all in (allows some wiggle room). i think i used a half inch drive and socket for the big nuts or bolts (mount to motor).
good luck. not a bad job.
