Msd 6al Question
smkshw
5 Year Member
Feb 12, 2010
1,095
235
94
hey guys
my car seems to run ok,just when i start it,its as if its firing up late?...not as crisp fire up as i want....so i disconected the original coil wires that hook up to the msd box,and pluged it back in the factory way to see if that helped,but it dosnt start?....shouldnt it fire if i hook it back to foctory plug?.....as far as i remember it used too?
its a 331 stroker thanks
  • Sponsors(?)
smkshw
5 Year Member
Feb 12, 2010
1,095
235
94
no only goes one way?....should work weird?....did my timing its at 14?....any thoughts guys?
smkshw
5 Year Member
Feb 12, 2010
1,095
235
94
i just dont get it?...msd is disconected?....and its dosnt fire?....hooked back up,and it fires?
the factory plug is giving the signal to the msd box?,should work?!
jrichker
StangNet's favorite TOOL
SN Certified Technician
Mar 10, 2000
27,347
2,822
234
74
Dublin GA
lowendmac.com
MSD wiring:
Instead of using the battery negative terminal, attach the heavy gauge black wire to the body ground point by the windshield washer filler.
The battery common ground is a 10 gauge pigtail with the computer ground attached to it.
Picture courtesy timewarped1972
smkshw
5 Year Member
Feb 12, 2010
1,095
235
94
MSD wiring:
the msd works,but when i unplug the factory plug to the msd,and plug it back to the coil,it dosnt start?.....so when its back to the stock way(msd deleted) car dosnt start?
i have the harness i should have said...so if u look at the diagram,i unplug it from there,wich makes the msd disconected from car,then i plug it back to coil instead of msd?
smkshw
5 Year Member
Feb 12, 2010
1,095
235
94
ok well here is a update if anyone cares....i have a msd coil....i put my stock coil back on and it fired perfectly!...with msd disconected....so i guess the coil was bad and the msd compensated....so thats that!
ps...thats the second msd coil in 2 years
Reactions: A5literMan
Thread starter Similar threads Forum Replies Date
smkshw Another Msd 6al Question Fox 5.0 Mustang Tech 12
mikestang63 Electrical Msd 6al And 8252 Coil Question Fox 5.0 Mustang Tech 0
Tom95gt Questions about my newly acquired MSD 6AL Box? 1994 - 1995 Specific Tech 7
Kurtis 2 quick electrical questions (MSD 6al box, tfi coil) Fox 5.0 Mustang Tech 3
Killercanary Question on buying a used MSD 6al 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
N msd problem need questions with a 6al box Fox 5.0 Mustang Tech 0
rdharper02 MSD 6al/SCI-l question? Sacralege? Fox 5.0 Mustang Tech 5
FastStang 2 MSD 6AL Ignition box Question Fox 5.0 Mustang Tech 6
8 MSD 6AL Wiring Question Fox 5.0 Mustang Tech 5
69shocktower Electrical Msd 6al Box And Distributor Install Classic Mustang Specific Tech 1
badfender911 Msd 6al Problems 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 26
G Does Anyone Know Anything About Msd 6al Digital Ignitio Fox 5.0 Mustang Tech 0
G New Msd 6al Digital Ignition 1994 - 1995 Specific Tech 2
C Expired MSD 6AL chip, MSD billet Distributor. Blaster 3 coil. Engine and Power Adder 0
B Msd 6al Digital Sucks!? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 36
8 Msd 6al-2 Engine and Power Adder 0
C MSD 6AL w/ Blaster 2 Coil $110 (Chicago) Other Classifieds 1
Andrew Montoya MSD 6Al Where to put? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 36
RAYZEN CAINE USED MSD 6AL Ignition Box Engine and Power Adder 0
S MSD 6AL Ignition Box for sale! Engine and Power Adder 6
S MSD 6AL Ignition Box for sale Engine and Power Adder Parts 0
T msd 6al-2 install Fox 5.0 Mustang Tech 1
I MSD 6al? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
B Could my msd 6AL box be the problem???? Fox 5.0 Mustang Tech 4
B Just installed MSD 6AL Fox 5.0 Mustang Tech 2
M msd 6al box Engine and Power Adder 4
8 MSD 6al 4 sale or trade Engine and Power Adder 0
8 MSD 6al Engine and Power Adder 0
Manewaymja2 Can I Use my MSD 6AL (RPM Pills)to Trigger my WOT Nitrous Switch Fox 5.0 Mustang Tech 2
garrett66 MSD 6AL worth it? Classic Mustang Specific Tech 2
B MSD 6AL-2 Programmable Classic Mustang Specific Tech 3
N msd harness extender 6al box Fox 5.0 Mustang Tech 3
mob Should I sell my MSD 6al? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
Cobra912 MSD 6AL - how to convert box from 4cyl back to 8cyl? Fox 5.0 Mustang Tech 4
punkn50 MSD 6al box Tach Problems Fox 5.0 Mustang Tech 4
Methodical MSD 6AL-2 mounting: Is it ok to mount the box in the trunk? 1994 - 1995 Specific Tech 3
Methodical MSD 6al-2 box.....Any user info on it Fox 5.0 Mustang Tech 1
Methodical MSD 6al-2 box.....Any user info on it 1994 - 1995 Specific Tech 4
ShortThrow50 How much could MY car benefit from the MSD 6AL? Fox 5.0 Mustang Tech 8
1991vert MSD 6AL or Digital-6? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
MikeROD16 MSD 6AL Fox 5.0 Mustang Tech 1
autumn_again MSD 6AL good? 1994 - 1995 Specific Tech 8
fobra559 MSD 6AL Ignition Box 1996 - 2004 SN95 Mustang -General/Talk- 5
9 1993 Mustang with MSD 6AL Gains? Fox 5.0 Mustang Tech 1
EMW150 MSD 6AL - Rough, Backfiring rev limiter/2-step Fox 5.0 Mustang Tech 0
flyinghi3 MSD 6al box electrical gremlin Fox 5.0 Mustang Tech 6
blksn955.o msd 6al quesiton 1994 - 1995 Specific Tech 4
Jaswir MSD 6al Box install? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
OonDeanisS anyone run a MSD 6AL with a blaster 2 coil? Fox 5.0 Mustang Tech 5
Prince95GT getting an MSD 6AL 1994 - 1995 Specific Tech 13
