Msd 6al2 Box Installation
I just bought a 6al2 ignition box for my carb 302 mustang.Im having installation isues i have the intructions but dont quite get them i have follow the diagram but its not working.Heres what i got done heavy red is connected to positive on the starter solenoid heavy black to negative on starter solenoid orange to + on coil black to - on coil.Now the magnetic pickup is green is splice to vilot and vilot is splice to orange.The problem is were do i get 12 volt ignition switch plz be specific as i am a noob to wireing just a bit tire of paying and not learning.
I havent double checked your other wiring, but I believe your asking for a place to connect to a switched 12v source. There may be a much better way, but in the past I have run my switched power out of the fuse box using a jumper or a "add a fuse" jumper. Below is Summit's version.
http://www.summitracing.com/parts/PCO-0957PT
For your 12 volt soure: Fuse 11 (radio) should be switched on/off with the ignition.
Heres a fuse box diagram if you need it
http://diagrams.hissind.com/?p=473
MSD wiring:
Instead of using the battery negative terminal, attach the heavy gauge black wire to the body ground point by the windshield washer filler.
The battery common ground is a 10 gauge pigtail with the computer ground attached to it.
Picture courtesy timewarped1972
