MSD TFI Problems?
50gt1988
154
Spanaway, WA
Well my ignition system is all new MSD but my car is showing signs of a bad TFI?
No hot start, untill engine cooled.
I thought the MSD TFIs didnt have overheating problems as bad as the stock TFIs?
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
www.dirtydirtyracing.com
if you are arent running a MSD distributor , pull your distributor out and put a pickup in it , and most parts stores can now test the TFI module for free ....tell them to run the test a few times to get it hot
Apr 8, 2004
791
El Paso, TX
Also check if there is heatsink grease on the back of the TFI module. I did not put any on when I got my MSD distributor, and I was having the same problem. Took the TFI module off, put some heat sink grease and no more problem.
50gt1988
154
Spanaway, WA
So Curse? What problems were you haveing before fixing it? Just so I can compare them to mine?
