I cleaned the pistons with acetone if I remember right. It’s the same chemical as the spray foam stuff. Yes I installed, the tfs stage 1 cam. Read the fine print on the heads and you’ll see they easily clear a cam under .500 lift.
I will. I called Edelbrock this morning and they told me that I would have to add relief when using the 60399 5.0 Performer heads with 2.02" intakes. I see you have the factory E7ZA- 0 -CA forged pistons. I am going to see if there is an installation note on the SVE heads at LMR. I won't know until I tear the engine apart and check. Your heads look like a copy of those that I have.
save up for a good set of afr or TW heads
I’m quite happy with the sve heads.
Standard valve angle heads this is correct . Those SVE heads are basically knock of Twisted wedge heads which work fine in this instance . I used tw heads with the same cam about 4-5 years ago and it worked fineI will. I called Edelbrock this morning and they told me that I would have to add relief when using the 60399 5.0 Performer heads with 2.02" intakes. I see you have the factory E7ZA- 0 -CA forged pistons. I am going to see if there is an installation note on the SVE heads at LMR. I won't know until I tear the engine apart and check. Your heads look like a copy of those that I have.
