You should not have to split anything. I went back and reread the thread. What MSD box are you running?
You say you have a SWITCHED 12v going to the MSD box. Tell us EXACTLY how you did this?
OK, I forgot about the MSD box earlier. All that is out the window. Nether of the wires matter at all. Referencing a MSD 6AL, ALL the orignal wires are removed from the coil. THe MSD Orange wire goes to the + coil post, the MSD Black goes to the coil - post. As long as you have SWITCHED 12v to the MSD Red wire in RUN position AND in the START postion of the ign switch, you should have no problems. If the car will not start with the key, you may not have switched 12v going to the MSD Red wire in the Start pos of the ign switch. Refer to you MSD directions exclusivly. Disregard all the BS I wrote. Sorry.
By "split" I mean tap into, or splice into, which is what I did with the red wire from the MSD 6a box. I tapped into the pink (even though it's not pink on my car) wire, which is supplying 12v when ignition is in the run position. So I need to get the switched "start-postion" wire connected to the red MSD wire.
