My microsquirt project
ummduh
Napa, CA
This is actually going in a 95 F250, 460/E4OD.
I know it's not a Mustang but it is very similar to 94/95 Mustangs and I was hoping to get get a couple tips anyways.
I am piggybacking the uS for now, eec controlling the trans. My plan is to learn how to use the platform and then transition the uS to the transmission and get an MS3 for the engine.
Anyways, I have a couple of probaby simple questions I haven't been able to sort out.
The truck is a remote mount ccd tfi.
1). On a lot of wiring guides, they have you putting a pull (up or down, don't remember) on the PIP. I have to leave the PIP connected to the eec for trans control so I wasn't sure if I should do that?
2). I have a Spartan 2 WB. The stock O2 is just wired off of a "hot in run" circuit. I understand you're not supposed to leave the WB powered up when not running. I was thinking of just putting in a relay triggered by the fuel pump trigger. Yea/nea? Hot in run good/bad?
I'm pretty paranoid about roasting my oem tfi module, I'll probably be switching back and forth (between the uS and the eec controlling the engine) a while til I get the hang of this.
Any help is definitely appreciated!
  • Sponsors(?)
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
10,634
6,827
214
33
Hillsborough county
The pullup is so the micro can fire the tfi circuit, totally normal. efisource uses a 330ohm for this but the documentation suggests a 1k i believe.
you wont fry the tfi unless you make some kind of major mistake.
ummduh
Napa, CA
Is it safe to have a pullup with it (it being the PIP output from tfi to eec and uS) connected to the eec though?
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
10,634
6,827
214
33
Hillsborough county
the stock eec has the pullup installed internally. I assume you are wiring these two in parallel permanently?? if thats the case simply put the pullup on a removable jumper or plug
ummduh
Napa, CA
Yes I guess you would say permanently. The eec needs PIP to control the transmission. So it'll be permanent until (if?) I remove the eec entirely.
