Narrowing it down starter
nards444
68
18
18
37
NY
New to me car and working through the eachs. One issue that I am dealing with is hot starting is an issue. New battery( was going to check it at autzone just for fun), alternator was already checked there. Checked all wires, tested the solenoid on the fire wall by jumping it and it works. So im down to the starter, just put a heat shield around it, wasnt able to wrap headers were are BBK as of yet, as it will be tough. Car is starts when cold, but after running it wouldnt start, with heat shield it will crank but its tough. Starter is not the old the coffee can original, but its older and not sure what it is. Anymore checks or advice before I rip it out and have it checked at autzone and replace it.
Also car seems to smell like gas , not super raw gas but it does. It doesnt have cats or smog but has headers. Checked the FPR wasnt fuel in the line but did have a slight fuel smell not terribly strong. Checked fuel pressure at idle and it was 38. Plugs were checked and seem somewhat worn but nothing crazy and probably be a replacement project this winter. I also have a 15 challenger which is quiet and doesnt stink, so trying to gauge if its just an old car with headers or something to take a look at.
  • Sponsors(?)
General karthief
Mod Dude
Aug 25, 2016
19,698
6,588
193
polk county florida
Have you checked for codes? There can be codes even without cel, but then you didn't say what year it is so some didn't have cel.
Smell fuel in the vacuum line of the fpr then I would replace it.
Of course now would be a good time to tell us about the twin turbos or any other modifications it has :jester:
Oh, do a voltage drop test on the cables, they can look good and still be burnt up. Do it after you heat soak it.
Reactions: 1 user
nards444
68
18
18
37
NY
its an 87 with a 302 bored to 306 with cam and headers. no turbos or blower. Havent checked for codes yet. As for the FPR, its faint smell of fuel but its there.
Monkeybutt2000
Advanced Member
Aug 11, 2019
582
389
73
49
Lafayette,IN
Check your cables for sure. I bought an 86 lx out of Tennessee years ago. Had to stop for gas on the drive back,car wouldn't start. Let it cool off for about half an hour. Had my girlfriend turning the key while I wiggled wires. Sure enough I wiggled the negative battery cable and car fired. Got it back home,replaced it. Someone had put a cheap clamp on cable end,all corroded inside.
jrichker
StangNet's favorite TOOL
SN Certified Technician
Mar 10, 2000
27,404
2,738
234
75
Dublin GA
lowendmac.com
@nards444
No Crank checklist for 5.0 Mustangs
Revised 24-Oct-2013 to update voltage drop figures.
No crank, slow crank and stuck starter solenoid problems have the same root causes – low battery voltage and poor connections. For that reason, they are grouped together.
Use the same initial group of tests to find the root cause of slow crank, no crank and stuck solenoid problems.
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
1.) Will the car start if it is jumped? Then clean battery terminals and check battery for low charge and dead cells. A good battery will measure 12-13 volts at full charge with the ignition switch in the Run position but without the engine running.
A voltmeter placed across the battery terminals should show a minimum of 9.5-10 volts when the ignition switch is turned to the Start position and the starter engages or tries to engage. Less than this will result in a clicking solenoid, or slow cranking (if it cranks at all) or a starter solenoid that sticks and welds the contacts together.
Most auto parts stores will check your battery for free. It does not have to be installed in the car to have it checked; you can carry it with you to the auto parts store.
The battery posts and inside of the battery post terminals should be scraped clean with a knife or battery post cleaner tool. This little trick will fix a surprising number of no start problems.
The clamp on with 2 bolts battery terminal ends are a known problem causer. Any place you see green on a copper wire is corrosion. Corrosion gets in the clamped joint and works its way up the wire under the insulation. Corroded connections do not conduct electricity well. Avoid them like the plague...
If the starter solenoid welds the contacts, then the starter will attempt to run anytime there is power in the battery. The cables and solenoid will get very hot, and may even start smoking. The temporary fix for a welded starter solenoid is to disconnect the battery and smack the back of the solenoid housing a sharp blow with a hammer. This may cause the contacts to unstick and work normally for a while.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection while trying to start the car: more than .25 volts across a connection indicates a problem. The voltage drop tests need to be done while cranking the engine. It's the current flowing through a connection or wire that causes the voltage drop.
See http://assets.fluke.com/appnotes/automotive/beatbook.pdf for help for help troubleshooting voltage drops across connections and components. .
attachments\64167
Voltage drops should not exceed the following:
200 mV Wire or cable
300 mV Switch or solenoid
100 mV Ground
0.0V Connections
A voltage drop lower that spec is always acceptable.
2.) Check the battery to engine block ground down near the oil filter, and the ground behind the engine to the firewall. All grounds should be clean and shiny. Use some sandpaper to clean them up.
3.) Jump the big terminals on the starter solenoid next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
The rest of the tech note only concerns no crank problems. If your problem was a stuck solenoid, go back to step 1.
4.) Then pull the small push on connector (small red/blue wire) off the starter solenoid (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it cranks, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems.
Typical start circuit...
attachments\21328
6.) Pull the starter and take it to AutoZone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
Starter solenoid wiring for 86-91 Mustang
attachments\52294
Starter solenoid wiring 92-93 Mustang or earlier Mustang with upgraded high torque mini starter.
attachments\53216
Electrical checks for the switches and starter solenoid
Remove the small red/blue wire from the starter solenoid. Use a screwdriver to bridge the connection from the battery positive connection on the starter solenoid to the small screw where the red/blue wire was connected. The starter should crank the engine. If it does not, the starter solenoid is defective or the battery lacks sufficient charge to crank the engine.
If the starter does crank the engine, the problem is in the clutch safety circuit (5 speed) or Neutral Sense Switch (auto trans) or ignition switch.
See the Typical start circuit diagram above for wiring information for troubleshooting.
You will need a voltmeter or test lamp for the rest of the checks. Connect one lead of the voltmeter or test lamp to ground. The other lead will connect to the item under test.
Look for 12 volts on the white/pink wire when the ignition switch is turned to the Start position. Check the ignition switch first.
No 12 volts, replace the ignition switch.
The next step will require you to push the clutch pedal to the floor (5 speed) or put the transmission in neutral (auto trans) while the ignition switch is turned to the Start position.
Good 12 volts, check the clutch safety switch (5 speed) or Neutral Sense Switch (auto trans) for good 12 volts on both sides of the switches. No 12 volts on both sides of the switch and the switches are defective or out of adjustment. Check the wiring for bad connections while you are at it.
  • Useful
Reactions: 1 user
