I have an 87 mustang gt, I recently put a 94 engine in I had to swap the distributor, it will run at tdc but it won't idle.. is there a crank or cam sensor in the motor I'm overlooking should it still run if there not hooked up? Should the throttle position sensor be recalibrated? Car is speed density, motor odviously mass air.. ANY help would be GREATLY appreciated. .thanks
